주요 콘텐츠로 건너뛰기
JBL Pulse 4 Drivers Replacement
필요한 것
  1. JBL Pulse 4 Drivers Replacement, Casing Replacement: 1 단계, 이미지 1개 중 1개
    • Power off the device before doing any repairs.
    • Hold the power button for 3+ seconds to power down the device.
  2. JBL Pulse 4 Drivers Replacement: 2 단계, 이미지 3개 중 1개 JBL Pulse 4 Drivers Replacement: 2 단계, 이미지 3개 중 2개 JBL Pulse 4 Drivers Replacement: 2 단계, 이미지 3개 중 3개
    • Remove each rubber end cap using a plastic pry tool.
    • Go around each end of the speaker slowly popping up a small section of the rubber cap until there is a gap on all sides.
    • Remove the top by hand.
  3. JBL Pulse 4 Drivers Replacement: 3 단계, 이미지 3개 중 1개 JBL Pulse 4 Drivers Replacement: 3 단계, 이미지 3개 중 2개 JBL Pulse 4 Drivers Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the charging port cover using a plastic pry tool.
    • Remove the two 12.7 mm Phillips #1 screws.
    • Remove the charging port housing from the casing.
  4. JBL Pulse 4 Drivers Replacement: 4 단계, 이미지 3개 중 1개 JBL Pulse 4 Drivers Replacement: 4 단계, 이미지 3개 중 2개 JBL Pulse 4 Drivers Replacement: 4 단계, 이미지 3개 중 3개
    • Disconnect the charging port connector by pulling the connector away from the port.
    • Disconnect the battery level indicator light by pulling the wire away from the lights.
  5. JBL Pulse 4 Drivers Replacement: 5 단계, 이미지 2개 중 1개 JBL Pulse 4 Drivers Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the six 8 mm Phillips #1 screws from the end of the speaker with the grill that says "JBL."
    • Remove the plastic piece where the 6 screws came out of.
  6. JBL Pulse 4 Drivers Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the six 9.5 mm screws using a Phillips #1 screwdriver.
  7. JBL Pulse 4 Drivers Replacement: 7 단계, 이미지 3개 중 1개 JBL Pulse 4 Drivers Replacement: 7 단계, 이미지 3개 중 2개 JBL Pulse 4 Drivers Replacement: 7 단계, 이미지 3개 중 3개
    • Flip the speaker to the other end.
    • Use a pry tool to pry between the casing of the speaker and the internals.
    • Go around the entirety of this end of the speaker slowly prying apart the two pieces.
  8. JBL Pulse 4 Drivers Replacement: 8 단계, 이미지 1개 중 1개
    • The casing is now fully detached from the internal components.
    • You can now replace the outer casing of the speaker.
  9. JBL Pulse 4 Drivers Replacement, LED Light Display: 9 단계, 이미지 2개 중 1개 JBL Pulse 4 Drivers Replacement, LED Light Display: 9 단계, 이미지 2개 중 2개
    • Place the speaker on the table with the button board side down.
    • Remove the three black 5 mm screws using a Phillips #1 screwdriver.
    • Remove the white casing by pulling it away from the button board.
  10. JBL Pulse 4 Drivers Replacement: 10 단계, 이미지 1개 중 1개
    • Clip off the two zip-ties using the zip tie cutter.
  11. JBL Pulse 4 Drivers Replacement: 11 단계, 이미지 1개 중 1개
    • Peel each LED strip off of the speaker using an iFixit opening pick.
  12. JBL Pulse 4 Drivers Replacement: 12 단계, 이미지 2개 중 1개 JBL Pulse 4 Drivers Replacement: 12 단계, 이미지 2개 중 2개
    • Remove the four black 5 mm screws using a Phillips #1 screwdriver.
    • Remove the white plastic piece that is held in place by the screws.
  13. JBL Pulse 4 Drivers Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the red/white cable from the white connection.
  14. JBL Pulse 4 Drivers Replacement: 14 단계, 이미지 1개 중 1개
    • Remove the LED light display from the speaker.
  15. JBL Pulse 4 Drivers Replacement, Battery: 15 단계, 이미지 3개 중 1개 JBL Pulse 4 Drivers Replacement, Battery: 15 단계, 이미지 3개 중 2개 JBL Pulse 4 Drivers Replacement, Battery: 15 단계, 이미지 3개 중 3개
  16. JBL Pulse 4 Drivers Replacement: 16 단계, 이미지 2개 중 1개 JBL Pulse 4 Drivers Replacement: 16 단계, 이미지 2개 중 2개
    • Unplug the cable connecting the battery to the motherboard.
  17. JBL Pulse 4 Drivers Replacement: 17 단계, 이미지 2개 중 1개 JBL Pulse 4 Drivers Replacement: 17 단계, 이미지 2개 중 2개
    • Feed the wire out of the central housing unit.
    • Pull the battery out of the central housing unit.
  18. JBL Pulse 4 Drivers Replacement, Button Board: 18 단계, 이미지 1개 중 1개
    • Cut the black cable off the motherboard using cutters to remove the button board.
  19. JBL Pulse 4 Drivers Replacement, Motherboard: 19 단계, 이미지 2개 중 1개 JBL Pulse 4 Drivers Replacement, Motherboard: 19 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using the tweezers, gently unplug the three connections attached to the motherboard.
  20. JBL Pulse 4 Drivers Replacement: 20 단계, 이미지 3개 중 1개 JBL Pulse 4 Drivers Replacement: 20 단계, 이미지 3개 중 2개 JBL Pulse 4 Drivers Replacement: 20 단계, 이미지 3개 중 3개
    • Pull the motherboard out of the frame.
    • The only connection the motherboard has to the frame now should be the soldered-on black wire.
  21. JBL Pulse 4 Drivers Replacement: 21 단계, 이미지 3개 중 1개 JBL Pulse 4 Drivers Replacement: 21 단계, 이미지 3개 중 2개 JBL Pulse 4 Drivers Replacement: 21 단계, 이미지 3개 중 3개
    • Desolder the wire from the motherboard.
    • Remove the motherboard from the speaker.
  22. JBL Pulse 4 Drivers Replacement, Drivers: 22 단계, 이미지 2개 중 1개 JBL Pulse 4 Drivers Replacement, Drivers: 22 단계, 이미지 2개 중 2개
    • Use a Phillips #00 screwdriver to remove the three 5 mm screws securing the plastic housing.
    • Remove the bumper assembly.
  23. JBL Pulse 4 Drivers Replacement: 23 단계, 이미지 1개 중 1개
    • Pull the bumper assembly away from the rest of the speaker.
    • Caution: Be gentle with the attached wires to avoid damaging them. Do not disconnect the wires while separating the parts.
  24. JBL Pulse 4 Drivers Replacement: 24 단계, 이미지 1개 중 1개
    • Disconnect the connector attached to the driver by gently pulling it apart.
    • Caution: Avoid pulling on the wires directly to prevent damage to the connector or internal wiring.
  25. JBL Pulse 4 Drivers Replacement: 25 단계, 이미지 2개 중 1개 JBL Pulse 4 Drivers Replacement: 25 단계, 이미지 2개 중 2개
    • Remove the driver from the plastic housing by gently pulling them apart.
    • Hold both the driver and housing firmly during this process.
    • Use a Phillips #00 screwdriver to remove any screws securing the driver, if necessary.
    • Caution: Avoid putting pressure on the driver or its connections to prevent damage.
결론
작성자
4다른 기여자 명과 함께
Wesley Henderson
회원 가입일: 02/25/25
109 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 23
전체 시간: 177
