주요 콘텐츠로 건너뛰기
JBL Pulse 4 Outside Casing Replacement
필요한 것
  1. JBL Pulse 4 Outside Casing Replacement, Casing Replacement: 1 단계, 이미지 1개 중 1개
    • Power off the device before doing any repairs.
    • Hold the power button for 3+ seconds to power down the device.
  2. JBL Pulse 4 Outside Casing Replacement: 2 단계, 이미지 3개 중 1개 JBL Pulse 4 Outside Casing Replacement: 2 단계, 이미지 3개 중 2개 JBL Pulse 4 Outside Casing Replacement: 2 단계, 이미지 3개 중 3개
    • Remove each rubber end cap using a plastic pry tool.
    • Go around each end of the speaker slowly popping up a small section of the rubber cap until there is a gap on all sides.
    • Remove the top by hand.
  3. JBL Pulse 4 Outside Casing Replacement: 3 단계, 이미지 3개 중 1개 JBL Pulse 4 Outside Casing Replacement: 3 단계, 이미지 3개 중 2개 JBL Pulse 4 Outside Casing Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the charging port cover using a plastic pry tool.
    • Remove the two 12.7 mm Phillips #1 screws.
    • Remove the charging port housing from the casing.
  4. JBL Pulse 4 Outside Casing Replacement: 4 단계, 이미지 3개 중 1개 JBL Pulse 4 Outside Casing Replacement: 4 단계, 이미지 3개 중 2개 JBL Pulse 4 Outside Casing Replacement: 4 단계, 이미지 3개 중 3개
    • Disconnect the charging port connector by pulling the connector away from the port.
    • Disconnect the battery level indicator light by pulling the wire away from the lights.
  5. JBL Pulse 4 Outside Casing Replacement: 5 단계, 이미지 2개 중 1개 JBL Pulse 4 Outside Casing Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the six 8 mm Phillips #1 screws from the end of the speaker with the grill that says "JBL."
    • Remove the plastic piece where the 6 screws came out of.
  6. JBL Pulse 4 Outside Casing Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the six 9.5 mm screws using a Phillips #1 screwdriver.
  7. JBL Pulse 4 Outside Casing Replacement: 7 단계, 이미지 3개 중 1개 JBL Pulse 4 Outside Casing Replacement: 7 단계, 이미지 3개 중 2개 JBL Pulse 4 Outside Casing Replacement: 7 단계, 이미지 3개 중 3개
    • Flip the speaker to the other end.
    • Use a pry tool to pry between the casing of the speaker and the internals.
    • Go around the entirety of this end of the speaker slowly prying apart the two pieces.
  8. JBL Pulse 4 Outside Casing Replacement: 8 단계, 이미지 1개 중 1개
    • The casing is now fully detached from the internal components.
    • You can now replace the outer casing of the speaker.
결론
작성자
4다른 기여자 명과 함께
Hank McDonough
회원 가입일: 03/18/24
377 평판
안내서 2개를 작성함
UMass Dartmouth, Team 2-2, Konn Spring 2024 UMass Dartmouth, Team 2-2, Konn Spring 2024 회원
UMASSD-KONN-S24S2G2
4 회원들
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 18
지난 30일: 49
전체 시간: 794
