소개
When the lights are displaying improperly, usually replacing the LED lights will fix the problem.
필요한 것
Use a plastic opening tool to pry around the edges of the circular rubber panel.
Once the edges are loose, pull off the rubber button panel completely.
I used a heat gun here to heat the adhesive before I attempted to pry. Using heat, I was able to remove the circuit board with the rubber overlay still attached. Use common sense on how much heat to apply. Don’t melt the plastic or rubber. Perhaps 60ºC
Lift the button board, exposing the attached cable.
Pull black piece on top of socket away from board to loosen, then detach the cable.
Take out the four 9mm black PH0 screws from the top and bottom of the device.
Pull off cap by hand.
The outer casing can now be removed.
Remove the tape around the cables on the top of the device.
Remove the cables by lifting up on the black bracket and then pulling the cable out.
다른 2명이 해당 안내서를 완성하였습니다.
