소개
An in depth guide on how to replace the motherboard in case of general unresponsiveness or faulty functionality.
필요한 것
Use a plastic opening tool to pry around the edges of the circular rubber panel.
Once the edges are loose, pull off the rubber button panel completely.
I used a heat gun here to heat the adhesive before I attempted to pry. Using heat, I was able to remove the circuit board with the rubber overlay still attached. Use common sense on how much heat to apply. Don’t melt the plastic or rubber. Perhaps 60ºC
Lift the button board, exposing the attached cable.
Pull black piece on top of socket away from board to loosen, then detach the cable.
Take out the four 9mm black PH0 screws from the top and bottom of the device.
Pull off cap by hand.
The outer casing can now be removed.
Remove the tape around the cables on the top of the device.
Remove the cables by lifting up on the black bracket and then pulling the cable out.
Remove two black 9mm PH0 screws from outside of inner casing on each side.
There are actually 5 screws to remove altogether. At least on my Pulse 1 there were. Two at the bottom, two at the top and the one in the center. The pic shows the one in the center and only one at the top.
true mine too
다른 3명이 해당 안내서를 완성하였습니다.
댓글 3개
Excelente, funcionó perfectamente la guia. Compré la bateria y el armado funcionó perfecto. Muchas gracias.
Hey I need JBL pulse motherboard Where can I buy. Please help
