소개
This guide is for replacing the outer casing of the JBL Pulse for when some kind of damage has occurred to the outside of the device.
필요한 것
Use a plastic opening tool to pry around the edges of the circular rubber panel.
Take out the four 9mm black PH0 screws from the top and bottom of the device.
Pull off cap by hand.
The outer casing can now be removed.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
