주요 콘텐츠로 건너뛰기
JBL Spyro/Spot Partial Disassembly
필요한 것
  1. JBL Spyro/Spot Partial Disassembly, Locate the risers: 1 단계, 이미지 1/1
    • Locate the 3 risers the hold the base plate in place
  2. JBL Spyro/Spot Partial Disassembly, Pry the plugs from the risers: 2 단계, 이미지 1/1
    • Insert a strong spudger or flathead near the riser and gently pry until the plug starts to come out. Work your way around to loosening each one.
  3. JBL Spyro/Spot Partial Disassembly, Remove the base plate: 3 단계, 이미지 1/1
    • With all three loosened remove the base!
    • Note the not equilateral placement of the risers when replacing the base.
결론
다른 17명이 해당 안내서를 완성하였습니다.
Ryan McLeod
회원 가입일: 05/22/10
606 평판
안내서 2개 작성하였습니다
댓글 11개
Thanks, so nice tip. I'll see if I can find a similar speaker, big hug.
durval - 답글
My speaker is broken like on the image above and it sounds horrible. Do you know where to buy similar speaker in order to replice it?
pszopa - 답글
Does anybody know, if I can get a replacement speaker for the subwoofer of the JBL 2.1. system? Thanks!
Lars -
I was unable to find a replacement for the Atlas subwoofer it uses and ended up "recycling" the whole thing :( I've since replaced it with the the Klipsch ProMedia 2.1s and love them.
Ryan McLeod -
I think you should add the phrase “JBL Spot” somewhere in this guide. Although I searched the web and iFixit, this guide didn’t come up because I was searching for JBL spot rather than JBL spyro.
TheLastMillennial - 답글
Fixed! Even if four years later haha
Ryan McLeod -
This was one of the best, especially for travel. You could find room for it in your suit case. It’s very lightweight for the amount of bass and beats you’re getting 36W in days before bluetooth battery speakers. I just found my old one in my parents garage and it working but static-y. ONe of the connection jacks serems to be the issue.
Tocki Cohi - 답글
The sound quality was great! But the legs on those little satellites were easy to break so idk personally about traveling with them!
Ryan McLeod -
De unde pot procura placa inferioară jbl. SPIRO? "subwoofer speacher satelite"?
Marian Cirjau - 답글
I doubt it but perhaps there are 3D files online or you could make your own with any material the screws can pass through!
Ryan McLeod -
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 19
30일 전: 105
전체 시간: 13,048
