이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide shows you how to remove the bottom plate, this provides access to the subwoofer itself.
필요한 것
Insert a strong spudger or flathead near the riser and gently pry until the plug starts to come out. Work your way around to loosening each one.
With all three loosened remove the base!
Note the not equilateral placement of the risers when replacing the base.
다른 17명이 해당 안내서를 완성하였습니다.
댓글 11개
No problem!!
My speaker is broken like on the image above and it sounds horrible. Do you know where to buy similar speaker in order to replice it?
Does anybody know, if I can get a replacement speaker for the subwoofer of the JBL 2.1. system? Thanks!
Lars -
I was unable to find a replacement for the Atlas subwoofer it uses and ended up "recycling" the whole thing :( I've since replaced it with the the Klipsch ProMedia 2.1s and love them.
