주요 콘텐츠로 건너뛰기
JBL Spyro/Spot Partial Disassembly
필요한 것
  1. JBL Spyro/Spot Partial Disassembly, Locate the risers: 1 단계, 이미지 1/1
    • Locate the 3 risers the hold the base plate in place
  2. JBL Spyro/Spot Partial Disassembly, Pry the plugs from the risers: 2 단계, 이미지 1/1
    • Insert a strong spudger or flathead near the riser and gently pry until the plug starts to come out. Work your way around to loosening each one.
  3. JBL Spyro/Spot Partial Disassembly, Remove the base plate: 3 단계, 이미지 1/1
    • With all three loosened remove the base!
    • Note the not equilateral placement of the risers when replacing the base.
결론
다른 17명이 해당 안내서를 완성하였습니다.
Ryan McLeod
회원 가입일: 05/22/10
606 평판
안내서 2개 작성하였습니다
댓글 11개
Thanks, so nice tip. I'll see if I can find a similar speaker, big hug.
durval - 답글
My speaker is broken like on the image above and it sounds horrible. Do you know where to buy similar speaker in order to replice it?
pszopa - 답글
Does anybody know, if I can get a replacement speaker for the subwoofer of the JBL 2.1. system? Thanks!
Lars -
I was unable to find a replacement for the Atlas subwoofer it uses and ended up "recycling" the whole thing :( I've since replaced it with the the Klipsch ProMedia 2.1s and love them.
Ryan McLeod -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 42
30일 전: 103
전체 시간: 13,017
