주요 콘텐츠로 건너뛰기
JBL Tune 510BT Faceplate Replacement
필요한 것
  1. JBL Tune 510BT Faceplate Replacement, Faceplate: 1 단계, 이미지 1/2 JBL Tune 510BT Faceplate Replacement, Faceplate: 1 단계, 이미지 2/2
    • Firmly grasp the earmuff and pull away from the center until the lip of the earmuff is disengaged.
    • Pull the earmuff towards the center of the headphones until it is free.
  2. JBL Tune 510BT Faceplate Replacement: 2 단계, 이미지 1/2 JBL Tune 510BT Faceplate Replacement: 2 단계, 이미지 2/2
    • Remove the three 3 mm screws using a JIS #00 screwdriver.
  3. JBL Tune 510BT Faceplate Replacement: 3 단계, 이미지 1/1
    • Carefully remove the faceplate by lifting it firmly.
    • Avoid rough movements, as there is a single thin wire connecting the faceplate to the internals.
    • If the repair is for the right-side driver, be mindful of the charging port, as the faceplate has a slot there for it. Lift the opposite end and back the port out.
    • To completely detach the faceplate, desolder the wires from the connections on the motherboard.
결론
Ryan
회원 가입일: 01/30/24
513 평판
안내서 4개 작성하였습니다
Utah Tech University, Team 1-2, McMurrin Spring 2024 Utah Tech University, Team 1-2, McMurrin Spring 2024 회원
UTAHTECH-MCMURRIN-S24S1G2
2 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 21
전체 시간: 58
