주요 콘텐츠로 건너뛰기
JBL Tune 710BT Battery Replacement
필요한 것
  1. JBL Tune 710BT Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Ensure your JBL Tune 710BT headphones are fully powered off.
    • Gather your tools and a clean, well-lit workspace.
  2. JBL Tune 710BT Battery Replacement: 2 단계, 이미지 1/1
    • Use the plastic opening tool to gently pry open the earcup covering the battery. This is usually found under the cushioned part of the earcup.
    • Be gentle to avoid damaging the earcup or the internal components.
  3. JBL Tune 710BT Battery Replacement: 3 단계, 이미지 1/1
    • Once disconnected, gently remove the old battery from the compartment.
    • If the battery is adhered in place, gently pry it loose, taking care not to damage the compartment or nearby components.
  4. JBL Tune 710BT Battery Replacement: 4 단계, 이미지 1/1
    • Place the new battery in the compartment, ensuring it sits flat and secure.
    • Reconnect the battery connector, ensuring it is snug and properly aligned.
  5. JBL Tune 710BT Battery Replacement: 5 단계, 이미지 1/1
    • Carefully align the earcup cover and press it back into place. Ensure all clips and seams are securely fastened and aligned.
    • Test the headphones to ensure the new battery is functioning correctly.
결론
After following these steps, your JBL Tune 710BT headphones should have a new lease on life with a fresh battery. Proper reassembly ensures the longevity and optimal performance of your headphones.
Additional Tips:
  • Handle all electronic components with care to avoid static discharge or damage.
  • Ensure the replacement battery is the correct model and specification for the JBL Tune 710BT headphones.
  • Dispose of the old battery properly, following local regulations for battery recycling.
By completing this guide, users can extend the lifespan of their JBL Tune 710BT headphones and enjoy uninterrupted listening experiences.
다른 한 분이 해당 안내서를 완성하였습니다.
Ethan Caleb Francis
회원 가입일: 03/18/24
150 평판
안내서 1개 작성함
UMass Dartmouth, Team 2-1, Konn Spring 2024 UMass Dartmouth, Team 2-1, Konn Spring 2024 회원
UMASSD-KONN-S24S2G1
4 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 21
30일 전: 21
전체 시간: 55
