주요 콘텐츠로 건너뛰기
JBL Xtreme 2 Speaker Replacement
필요한 것
  1. JBL Xtreme 2 Speaker Replacement, Speaker: 1 단계, 이미지 1/2 JBL Xtreme 2 Speaker Replacement, Speaker: 1 단계, 이미지 2/2
    • Use a spudger or other prying tool to gently pry open the middle section of the speaker.
  2. JBL Xtreme 2 Speaker Replacement: 2 단계, 이미지 1/2 JBL Xtreme 2 Speaker Replacement: 2 단계, 이미지 2/2
    • To open the case, open the front side gently rotating along the hinge.
  3. JBL Xtreme 2 Speaker Replacement: 3 단계, 이미지 1/1
    • Once you have the speakers exposed like in the image, at the bottom part you will snap open the back end piece of the grill still attached.
  4. JBL Xtreme 2 Speaker Replacement: 4 단계, 이미지 1/3 JBL Xtreme 2 Speaker Replacement: 4 단계, 이미지 2/3 JBL Xtreme 2 Speaker Replacement: 4 단계, 이미지 3/3
    • Using a Phillips #00 screwdriver, remove the four 12.9 mm screws securing the faulty speaker.
    • Once you remove the screws, the speaker will be loose and you will be able to move it around easily.
  5. JBL Xtreme 2 Speaker Replacement: 5 단계, 이미지 1/3 JBL Xtreme 2 Speaker Replacement: 5 단계, 이미지 2/3 JBL Xtreme 2 Speaker Replacement: 5 단계, 이미지 3/3
    • Lift the speaker out of its housing and you will see two cables connecting the speaker. Pull the speaker towards you and each of the cable connectors away from you.
    • Do the same for both cables.
결론
다른 2명이 해당 안내서를 완성하였습니다.
charlymoron
회원 가입일: 10/30/22
169 평판
안내서 1개 작성함
CSU Los Angeles, Team 51-51, Briggs Fall 2022 CSU Los Angeles, Team 51-51, Briggs Fall 2022 회원
CSULA-BRIGGS-F22S51G51
1 회원
안내서 2개 작성하였습니다
댓글 한 개
Jep u open it wrong way. I broken My speaker Plastic attachment so i need extra work whit wrong opening way. I can sent u a some pic whit this.
Bender - 답글
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 29
30일 전: 120
전체 시간: 2,403
