주요 콘텐츠로 건너뛰기
JBL Xtreme 3 Battery Replacement
필요한 것
  1. JBL Xtreme 3 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Begin by placing the speaker with the grooves on the bottom of the device facing towards you.
    • Use a spudger to carefully pry around the seams of the speaker to open and unlatch the outer shell.
    • Use your hands to finish removing the outer case of the device.
  2. JBL Xtreme 3 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to remove the two 10 mm screws.
  3. JBL Xtreme 3 Battery Replacement: 3 단계, 이미지 2개 중 1개 JBL Xtreme 3 Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Use a spudger to carefully pry open the latch located above the control button as shown in the photo. Please be careful!!!
    • Remove the speaker from the shell.
  4. JBL Xtreme 3 Battery Replacement: 4 단계, 이미지 2개 중 1개 JBL Xtreme 3 Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Turn the device so that the control buttons are facing down.
    • Use a Phillips #1 screwdriver to remove the eight 10 mm screws from the panel.
    • Carefully remove the panel.
  5. JBL Xtreme 3 Battery Replacement: 5 단계, 이미지 2개 중 1개 JBL Xtreme 3 Battery Replacement: 5 단계, 이미지 2개 중 2개
    • The battery is connected to a cable. Use gentle force.
    • Use the spudger to carefully pry the battery out.
  6. JBL Xtreme 3 Battery Replacement: 6 단계, 이미지 3개 중 1개 JBL Xtreme 3 Battery Replacement: 6 단계, 이미지 3개 중 2개 JBL Xtreme 3 Battery Replacement: 6 단계, 이미지 3개 중 3개
    • Use the plastic opening tool to press the white notch while simultaneously unplugging the battery connector.
    • Plug in the replacement.
    • Make sure the new battery is secure. Turn on the device to ensure that the battery is connected properly.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Maria
회원 가입일: 09/16/22
514 평판
안내서 3개를 작성함
1가이드 댓글
Great guide! Thank you!
dam damo - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 29
지난 30일: 157
전체 시간: 5,622
