주요 콘텐츠로 건너뛰기
JBL Xtreme 3 Exterior Speaker Shell Cover Replacement
필요한 것
  1. JBL Xtreme 3 Exterior Speaker Shell Cover Replacement, Exterior Speaker Shell Cover: 1 단계, 이미지 1개 중 1개
    • Find the seam on the speaker and position it upwards.
    • Begin by turning the device to where the bottom side with groves are facing towards you, using the (5) spudger carefully pry open the side of the outer shell where the red indicators are to unlatch outer shell. After they are unlatched you should be able to open the shell by hand.
  2. JBL Xtreme 3 Exterior Speaker Shell Cover Replacement: 2 단계, 이미지 1개 중 1개
    • To continue to remove the outer shell unscrew the two screws (size 1cm) shown in the picture with a size 0 (zero) Phillip's screwdriver.
  3. JBL Xtreme 3 Exterior Speaker Shell Cover Replacement: 3 단계, 이미지 2개 중 1개 JBL Xtreme 3 Exterior Speaker Shell Cover Replacement: 3 단계, 이미지 2개 중 2개
    • To continue to remove the shell use a (5) spudger to slowly pop the shell off.
    • There is one nudge in the center below the power and bluetooth button that should pop off.
    • Once you have unlatched this piece correctly the shell will remove itself from the speaker itself. As it is shown in the following figure.
결론
작성자
4다른 기여자 명과 함께
Devon Shaw
회원 가입일: 09/16/22
220 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 30
전체 시간: 1,288
