주요 콘텐츠로 건너뛰기
JBL Xtreme 3 Speaker Replacement
필요한 것
  1. JBL Xtreme 3 Speaker Replacement, Exterior Speaker Shell Cover: 1 단계, 이미지 1/1
    • Find the seam on the speaker and position it upwards.
    • Begin by turning the device to where the bottom side with groves are facing towards you, using the (5) spudger carefully pry open the side of the outer shell where the red indicators are to unlatch outer shell. After they are unlatched you should be able to open the shell by hand.
  2. JBL Xtreme 3 Speaker Replacement: 2 단계, 이미지 1/1
    • To continue to remove the outer shell unscrew the two screws (size 1cm) shown in the picture with a size 0 (zero) Phillip's screwdriver.
  3. JBL Xtreme 3 Speaker Replacement: 3 단계, 이미지 1/2 JBL Xtreme 3 Speaker Replacement: 3 단계, 이미지 2/2
    • To continue to remove the shell use a (5) spudger to slowly pop the shell off.
    • There is one nudge in the center below the power and bluetooth button that should pop off.
    • Once you have unlatched this piece correctly the shell will remove itself from the speaker itself. As it is shown in the following figure.
  4. JBL Xtreme 3 Speaker Replacement, Speaker: 4 단계, 이미지 1/1
    • Once the shell has been romved use a #2 phillip's screwdriver to remove the 8 screws on the two speaker.
    • Repeats the first step for the second speaker.
  5. JBL Xtreme 3 Speaker Replacement: 5 단계, 이미지 1/1
    • Use a spudger to prop speaker out.
  6. JBL Xtreme 3 Speaker Replacement: 6 단계, 이미지 1/1
    • Carefully squeeze the clip on each cable and pull it to disconnect the speaker.
    • Replace the speaker.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Maria
회원 가입일: 09/16/22
472 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 17
30일 전: 73
전체 시간: 1,443
