주요 콘텐츠로 건너뛰기
JBL Xtreme 4 Charging Port Replacement
필요한 것
  1. JBL Xtreme 4 Charging Port Replacement, Battery: 1 단계, 이미지 3개 중 1개 JBL Xtreme 4 Charging Port Replacement, Battery: 1 단계, 이미지 3개 중 2개 JBL Xtreme 4 Charging Port Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Use a T20 Torx screwdriver to remove the two 12.5 mm screws that secure the battery cover.
  2. JBL Xtreme 4 Charging Port Replacement: 2 단계, 이미지 1개 중 1개
    • Using your fingernail or a spudger, pry open the battery cover.
  3. JBL Xtreme 4 Charging Port Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the battery by pinching the orange ribbon and gently pulling the battery upwards and out of its slot.
  4. JBL Xtreme 4 Charging Port Replacement, Outside Cover: 4 단계, 이미지 2개 중 1개 JBL Xtreme 4 Charging Port Replacement, Outside Cover: 4 단계, 이미지 2개 중 2개
    • Insert the flat end of a spudger into the mesh cover seam beside the battery compartment.
    • Pry on both sides of the battery compartment until the mesh cover releases.
  5. JBL Xtreme 4 Charging Port Replacement: 5 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the two 8.5 mm screws on either side of the battery compartment.
  6. JBL Xtreme 4 Charging Port Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the speaker out of the cover.
  7. JBL Xtreme 4 Charging Port Replacement, Charging Port: 7 단계, 이미지 3개 중 1개 JBL Xtreme 4 Charging Port Replacement, Charging Port: 7 단계, 이미지 3개 중 2개 JBL Xtreme 4 Charging Port Replacement, Charging Port: 7 단계, 이미지 3개 중 3개
    • Remove the two 8.5 mm Phillips screws on the charging port cover.
    • Pry the cover off with an opening tool.
  8. JBL Xtreme 4 Charging Port Replacement: 8 단계, 이미지 1개 중 1개
    • Pull the charging port out of the device.
    • Take care not to strain the connected cables.
  9. JBL Xtreme 4 Charging Port Replacement: 9 단계, 이미지 2개 중 1개 JBL Xtreme 4 Charging Port Replacement: 9 단계, 이미지 2개 중 2개
    • Disconnect the ribbon cable by gently pulling it out.
  10. JBL Xtreme 4 Charging Port Replacement: 10 단계, 이미지 2개 중 1개 JBL Xtreme 4 Charging Port Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the final cable connection by pinching the tab and pulling it directly out of its socket.
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Thomas Holloway
회원 가입일: 02/20/25
925 평판
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 30
지난 30일: 109
전체 시간: 525
