주요 콘텐츠로 건너뛰기
JBL Xtreme 4 Passive Radiator Replacement
필요한 것
  1. JBL Xtreme 4 Passive Radiator Replacement, Battery: 1 단계, 이미지 3개 중 1개 JBL Xtreme 4 Passive Radiator Replacement, Battery: 1 단계, 이미지 3개 중 2개 JBL Xtreme 4 Passive Radiator Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Use a T20 Torx screwdriver to remove the two 12.5 mm screws that secure the battery cover.
  2. JBL Xtreme 4 Passive Radiator Replacement: 2 단계, 이미지 1개 중 1개
    • Using your fingernail or a spudger, pry open the battery cover.
  3. JBL Xtreme 4 Passive Radiator Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the battery by pinching the orange ribbon and gently pulling the battery upwards and out of its slot.
  4. JBL Xtreme 4 Passive Radiator Replacement, Outside Cover: 4 단계, 이미지 2개 중 1개 JBL Xtreme 4 Passive Radiator Replacement, Outside Cover: 4 단계, 이미지 2개 중 2개
    • Insert the flat end of a spudger into the mesh cover seam beside the battery compartment.
    • Pry on both sides of the battery compartment until the mesh cover releases.
  5. JBL Xtreme 4 Passive Radiator Replacement: 5 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the two 8.5 mm screws on either side of the battery compartment.
  6. JBL Xtreme 4 Passive Radiator Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the speaker out of the cover.
  7. JBL Xtreme 4 Passive Radiator Replacement, Passive Radiator: 7 단계, 이미지 3개 중 1개 JBL Xtreme 4 Passive Radiator Replacement, Passive Radiator: 7 단계, 이미지 3개 중 2개 JBL Xtreme 4 Passive Radiator Replacement, Passive Radiator: 7 단계, 이미지 3개 중 3개
    • Use a Phillips screwdriver to remove the three 8.5 mm screws on the tweeter.
    • Pull the tweeter out from the device.
  8. JBL Xtreme 4 Passive Radiator Replacement: 8 단계, 이미지 2개 중 1개 JBL Xtreme 4 Passive Radiator Replacement: 8 단계, 이미지 2개 중 2개
    • Pinch the cable connection for the tweeters and pull off.
    • Repeat the previous bullet for the second cable.
  9. JBL Xtreme 4 Passive Radiator Replacement: 9 단계, 이미지 3개 중 1개 JBL Xtreme 4 Passive Radiator Replacement: 9 단계, 이미지 3개 중 2개 JBL Xtreme 4 Passive Radiator Replacement: 9 단계, 이미지 3개 중 3개
    • Use a Phillips the four 12.4 mm screws that secure the passive radiator.
  10. JBL Xtreme 4 Passive Radiator Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the passive radiator from the body of the speaker.
결론
작성자
2다른 기여자 명과 함께
Thomas Holloway
회원 가입일: 02/20/25
925 평판
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 10
지난 30일: 40
전체 시간: 209
