주요 콘텐츠로 건너뛰기
JBL Xtreme Akku austauschen high power
필요한 것
  1. JBL Xtreme Akku austauschen high power, Akku: 1 단계, 이미지 1개 중 1개
    • 8,4 V externer Akku für JBL Extreme
  2. JBL Xtreme Akku austauschen high power: 2 단계, 이미지 1개 중 1개
    • Gehäuse aufschrauben dazu die Hülle entfernen.
  3. JBL Xtreme Akku austauschen high power: 3 단계, 이미지 1개 중 1개
    • Akkufach mit 8 Schrauben lösen. Akku entfernen. Loch bohren. Löcher wegen der Luftdichtigkeit mit Heißkleber verschließen.
  4. JBL Xtreme Akku austauschen high power: 4 단계, 이미지 2개 중 1개 JBL Xtreme Akku austauschen high power: 4 단계, 이미지 2개 중 2개
    • Anschlüsser + und - verlöten. Zur Stromversogung einen DC Hohlbuchse 5.5 x 2.1 verwenden. Kabelenden Isolieren.
  5. JBL Xtreme Akku austauschen high power: 5 단계, 이미지 1개 중 1개
    • Akku 8,4 Volt. 13200mAh 8,4V Akku Batterie-Pack Ladegeraet für Fahrradlampe-XML-T6
  6. JBL Xtreme Akku austauschen high power: 6 단계, 이미지 1개 중 1개
    • Solarstorm 2S2P 18650 Battery Case.
    • 4xPanasonic NCR18650B 3,7V 3400mAh=14400 mAh
    • + 5V USB ON/OFF Button
결론
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Bert
회원 가입일: 06/27/17
253 평판
안내서 1개를 작성함
6가이드 댓글
hi
step 2: unscrew the screws …. thats th point, where are the screws. the body looks like glued.
stephan dingsda - 답글
Hi.
Don’t ask me, because I have this guide only translated not created. Try to contact the author on de.ifixit.com. I have translated it so, that I tried to don’t change the original text.
Martin
Martin Kubica - 답글
I didn’t get it quite clear: is there a original battery replacement or an improvised one? I am interested in replacing mine but I didn’t find the battery.
Chris Fotu - 답글
Hi.
See the comment higher.
Martin Kubica
Martin Kubica - 답글
WTF?!? Don’t do this. Buy a replacement battery online, and swap it out. Don’t drill holes, add glue, and try to cram in some battery that isn’t built for it!
fixit4 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 35
지난 30일: 103
전체 시간: 30,053
