주요 콘텐츠로 건너뛰기
JBL Xtreme Bass Radiator Replacement
필요한 것
  1. JBL Xtreme Bass Radiator Replacement, Cover: 1 단계, 이미지 1개 중 1개
    • Locate the seams next to the 'feet' on the bottom side of the device.
  2. JBL Xtreme Bass Radiator Replacement: 2 단계, 이미지 2개 중 1개 JBL Xtreme Bass Radiator Replacement: 2 단계, 이미지 2개 중 2개
    • Use the metal spudger to gently pry and lift the edge of the seam. The cover is held in place with plastic snaps that will make a popping noise when disengaged. !!Start with the back half, this will expose TWO Screws that need to be removed before lifting the front half.
  3. JBL Xtreme Bass Radiator Replacement: 3 단계, 이미지 2개 중 1개 JBL Xtreme Bass Radiator Replacement: 3 단계, 이미지 2개 중 2개
    • For the first part of the case: gently pull back the edges of the case rotating along the hinge opposite the opening seam illustrated in the second photo. Plastic snaps hold the cover in place.
    • For the second part of the case: there are 2 screws to be removed at the seam. Once removed, the case will come off completely without forcing.
  4. JBL Xtreme Bass Radiator Replacement, Bass Radiator: 4 단계, 이미지 3개 중 1개 JBL Xtreme Bass Radiator Replacement, Bass Radiator: 4 단계, 이미지 3개 중 2개 JBL Xtreme Bass Radiator Replacement, Bass Radiator: 4 단계, 이미지 3개 중 3개
    • Unscrew the six 9.75mm Phillips head screws holding the bass radiator in place.
    • Three of the five outer screws are indicated in the first image and the sixth inner screw is indicated in the second image.
  5. JBL Xtreme Bass Radiator Replacement: 5 단계, 이미지 3개 중 1개 JBL Xtreme Bass Radiator Replacement: 5 단계, 이미지 3개 중 2개 JBL Xtreme Bass Radiator Replacement: 5 단계, 이미지 3개 중 3개
    • Once the screws have been removed, the bass radiator will easily lift free.
    • Both radiators are identical. Repeat the above steps on the opposite radiator if necessary.
결론
다른 12명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Benny Huynh
회원 가입일: 02/15/17
2,031 평판
안내서 4개를 작성함
USF Tampa, Team 1-1, Sullivan Spring 2017 USF Tampa, Team 1-1, Sullivan Spring 2017 회원
USFT-SULLIVAN-S17S1G1
4 회원들
안내서 28개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 15
지난 30일: 61
전체 시간: 22,168
