주요 콘텐츠로 건너뛰기
JBL Xtreme Battery Replacement
필요한 것
  1. JBL Xtreme Battery Replacement, Cover: 1 단계, 이미지 1/1
    • Locate the seams next to the 'feet' on the bottom side of the device.
  2. JBL Xtreme Battery Replacement: 2 단계, 이미지 1/2 JBL Xtreme Battery Replacement: 2 단계, 이미지 2/2
    • Use the metal spudger to gently pry and lift the edge of the seam. The cover is held in place with plastic snaps that will make a popping noise when disengaged. !!Start with the back half, this will expose TWO Screws that need to be removed before lifting the front half.
  3. JBL Xtreme Battery Replacement: 3 단계, 이미지 1/2 JBL Xtreme Battery Replacement: 3 단계, 이미지 2/2
    • For the first part of the case: gently pull back the edges of the case rotating along the hinge opposite the opening seam illustrated in the second photo. Plastic snaps hold the cover in place.
    • For the second part of the case: there are 2 screws to be removed at the seam. Once removed, the case will come off completely without forcing.
  4. JBL Xtreme Battery Replacement, Bass Radiator: 4 단계, 이미지 1/3 JBL Xtreme Battery Replacement, Bass Radiator: 4 단계, 이미지 2/3 JBL Xtreme Battery Replacement, Bass Radiator: 4 단계, 이미지 3/3
    • Unscrew the six 9.75mm Phillips head screws holding the bass radiator in place.
    • Three of the five outer screws are indicated in the first image and the sixth inner screw is indicated in the second image.
  5. JBL Xtreme Battery Replacement: 5 단계, 이미지 1/3 JBL Xtreme Battery Replacement: 5 단계, 이미지 2/3 JBL Xtreme Battery Replacement: 5 단계, 이미지 3/3
    • Once the screws have been removed, the bass radiator will easily lift free.
    • Both radiators are identical. Repeat the above steps on the opposite radiator if necessary.
  6. JBL Xtreme Battery Replacement, Battery: 6 단계, 이미지 1/3 JBL Xtreme Battery Replacement, Battery: 6 단계, 이미지 2/3 JBL Xtreme Battery Replacement, Battery: 6 단계, 이미지 3/3
    • Locate the three 9.7mm Phillips head screws inside the zipper compartment and unscrew them.
    • Lift the zipper panel out of the speaker.
    • The side of the panel opposite the screws is held in place by small clamps. The panel should easily lift free from the device, but may require gentle prying.
  7. JBL Xtreme Battery Replacement: 7 단계, 이미지 1/2 JBL Xtreme Battery Replacement: 7 단계, 이미지 2/2
    • Under the zipper panel are eight more 9.75mm Phillips head screws. Unscrew them and carefully lift the battery cover.
    • Be careful not to damage the small white ribbon cable which connects the battery cover to the rest of the device.
    • 2 small screws hold this part to the cover. For ease of future handling, remove them and gently pull this part out to release the cover.
  8. JBL Xtreme Battery Replacement: 8 단계, 이미지 1/2 JBL Xtreme Battery Replacement: 8 단계, 이미지 2/2
    • Locate the cable illustrated in this picture.
    • Gently unplug the cable from the motherboard.
  9. JBL Xtreme Battery Replacement: 9 단계, 이미지 1/3 JBL Xtreme Battery Replacement: 9 단계, 이미지 2/3 JBL Xtreme Battery Replacement: 9 단계, 이미지 3/3
    • Carefully lift the battery free of the device, threading the cable through the hole in the case as you do so.
결론
다른 78명이 해당 안내서를 완성하였습니다.
Sylvain Bazile
회원 가입일: 02/15/17
1,041 평판
안내서 1개 작성함
USF Tampa, Team 1-1, Sullivan Spring 2017 USF Tampa, Team 1-1, Sullivan Spring 2017 회원
USFT-SULLIVAN-S17S1G1
4 회원들
안내서 25개 작성하였습니다
33 댓글
What model of battery do you need if replacing? Thanks
sean - 답글
I couldn't find the battery specification anywhere in the Internet, so I removed it, easily following the well presented instructions above. The battery has two cells. The label on each cell says Greatpower, model no. GSP0931134, 7.4 volts, 5000 mah, 37Wh, made in China. Overall dimensions are 145mm x 32mm x 19mm (145mm includes a small electronic board where cables from the board connect to the plug.) After an Amazon and Google search, I'm no closer to a replacement. At least the reassembled Xtreme works without a battery with external power. JBL is of no help, either. I'll be looking model airplane stores, as they have every LiPo battery imaginable. In summary, the JBL Xtreme is a short lived unsupported product.
Gustavo Garcia Swengel - 답글
This is kinda late but were there any extra steps for running the speaker without a battery? Since the speaker is not working anymore at all, even with power connected, I would be happy to run it like this but am not sure whether it is really enough to just remove the battery.
Roland Deschain -
this &&^&^$^ jbl costumer support service is charging me $110 for battery replacement, and a $30 service charge, it cost half of the speaker price,
christian cometa - 답글
Same here in Hungary.
I’ve got a battery issue (a full charge lasts only about 3-4 hours of playback on mid volume) after a little more than 1 year of usage…
110 US dollars for replacement. Nonsense!
Mark Rakoczi -
댓글 쓰기
조회 통계:
24 시간 전: 27
7일 전: 265
30일 전: 1,248
전체 시간: 105,698
