이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use the metal spudger to gently pry and lift the edge of the seam. The cover is held in place with plastic snaps that will make a popping noise when disengaged. !!Start with the back half, this will expose TWO Screws that need to be removed before lifting the front half.
For the first part of the case: gently pull back the edges of the case rotating along the hinge opposite the opening seam illustrated in the second photo. Plastic snaps hold the cover in place.
For the second part of the case: there are 2 screws to be removed at the seam. Once removed, the case will come off completely without forcing.
Unscrew the six 9.75mm Phillips head screws holding the bass radiator in place.
Once the screws have been removed, the bass radiator will easily lift free.
Locate the three Phillips head screws inside the zipper compartment and unscrew them.
Pull the zipper panel free from the device.
Under the zipper panel are eight more Phillips head screws. Unscrew them and carefully lift the battery cover.
Unscrew the three 11.88mm Phillips head screws highlighted in the picture.
The first image highlights the charging port.
Locate 6 metal pins highlighted in the second image and use a solder iron to disconnect the pins.
다른 14명이 해당 안내서를 완성하였습니다.
댓글 한 개
Please I have a JBL XTREME that sparks each time I plug it. What could be the cause
