주요 콘텐츠로 건너뛰기
JBL Xtreme Cover Disassembly
필요한 것
  1. JBL Xtreme Cover Disassembly, Cover: 1 단계, 이미지 1/1
    • Locate the seams next to the 'feet' on the bottom side of the device.
  2. JBL Xtreme Cover Disassembly: 2 단계, 이미지 1/2 JBL Xtreme Cover Disassembly: 2 단계, 이미지 2/2
    • Use the metal spudger to gently pry and lift the edge of the seam. The cover is held in place with plastic snaps that will make a popping noise when disengaged. !!Start with the back half, this will expose TWO Screws that need to be removed before lifting the front half.
  3. JBL Xtreme Cover Disassembly: 3 단계, 이미지 1/2 JBL Xtreme Cover Disassembly: 3 단계, 이미지 2/2
    • For the first part of the case: gently pull back the edges of the case rotating along the hinge opposite the opening seam illustrated in the second photo. Plastic snaps hold the cover in place.
    • For the second part of the case: there are 2 screws to be removed at the seam. Once removed, the case will come off completely without forcing.
결론
다른 14명이 해당 안내서를 완성하였습니다.
Benny Huynh
회원 가입일: 02/15/17
1,766 평판
안내서 4개 작성하였습니다
USF Tampa, Team 1-1, Sullivan Spring 2017 USF Tampa, Team 1-1, Sullivan Spring 2017 회원
USFT-SULLIVAN-S17S1G1
4 회원들
안내서 25개 작성하였습니다
5 댓글
Can you fix my cover on speaker
c_pg08 - 답글
where can I find a new cover for xtreme 2, if possible in black?
vale0501 - 답글
If you find a place to buy a cover let me know
abjayaman -
you forgot about 2 screws
Enescu Catalin - 답글
zapomniałeś o śrubach osoby które o tym mogły nie wiedzieć mogły urwać plastikowy haczyk który utrzymuje przód
megakacper11 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 43
30일 전: 241
전체 시간: 27,828
