소개
This will show how to change the battery .
필요한 것
다른 2명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 6개
hi
step 2: unscrew the screws …. thats th point, where are the screws. the body looks like glued.
Hi.
Don’t ask me, because I have this guide only translated not created. Try to contact the author on de.ifixit.com. I have translated it so, that I tried to don’t change the original text.
Martin
I didn’t get it quite clear: is there a original battery replacement or an improvised one? I am interested in replacing mine but I didn’t find the battery.
Chris Fotu - 답글
Hi.
See the comment higher.
Martin Kubica
WTF?!? Don’t do this. Buy a replacement battery online, and swap it out. Don’t drill holes, add glue, and try to cram in some battery that isn’t built for it!
Yeah, what the hell is it. Just use that youtube video of that company that sells batteries (it should come up as one of the first on youtube). Extra info:
1. Use a proper fit phillips screwdriver; apparently the screws are very tightly put in and you could damage the screwheads.
2. There are apparently nine and not 8 screws there were he mentions it; one should be under some tape.
3. Apparently that outer cover is glued pretty hard on the plastic. Be aware of that and use the best tool you can find that is plastic and maybe more than one, so you will avoid damaging anything.
4. Apparently the original battery has some type of glue put on the connector, which makes it harder to get the connector out. Try using plastic and not metal there as well, as you might damage the board it's connected to.
Note: I said apparently as this is what I read in comments. You might find it's different when you do it but keep these things I mind so you are prepared. And again: this guide is indeed bullshit.
