주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
JBL Xtreme Akku Replacement high power
필요한 것
  1. JBL Xtreme Akku Replacement high power, Akku: 1 단계, 이미지 1/1
    • 8,4 V externer Akku für JBL Extreme
  2. JBL Xtreme Akku Replacement high power: 2 단계, 이미지 1/1
    • Gehäuse aufschrauben dazu die Hülle entfernen.
  3. JBL Xtreme Akku Replacement high power: 3 단계, 이미지 1/1
    • Akkufach mit 8 Schrauben lösen. Akku entfernen. Loch bohren. Löcher wegen der Luftdichtigkeit mit Heißkleber verschließen.
  4. JBL Xtreme Akku Replacement high power: 4 단계, 이미지 1/2 JBL Xtreme Akku Replacement high power: 4 단계, 이미지 2/2
    • Anschlüsser + und - verlöten. Zur Stromversogung einen DC Hohlbuchse 5.5 x 2.1 verwenden. Kabelenden Isolieren.
  5. JBL Xtreme Akku Replacement high power: 5 단계, 이미지 1/1
    • Akku 8,4 Volt. 13200mAh 8,4V Akku Batterie-Pack Ladegeraet für Fahrradlampe-XML-T6
  6. JBL Xtreme Akku Replacement high power: 6 단계, 이미지 1/1
    • Solarstorm 2S2P 18650 Battery Case.
    • 4xPanasonic NCR18650B 3,7V 3400mAh=14400 mAh
    • + 5V USB ON/OFF Button
결론
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
다른 2명이 해당 안내서를 완성하였습니다.
Bert
회원 가입일: 06/27/17
217 평판
안내서 1개 작성함
댓글 6개
hi
step 2: unscrew the screws …. thats th point, where are the screws. the body looks like glued.
stephan dingsda - 답글
Hi.
Don’t ask me, because I have this guide only translated not created. Try to contact the author on de.ifixit.com. I have translated it so, that I tried to don’t change the original text.
Martin
Martin Kubica - 답글
I didn’t get it quite clear: is there a original battery replacement or an improvised one? I am interested in replacing mine but I didn’t find the battery.
Chris Fotu - 답글
Hi.
See the comment higher.
Martin Kubica
Martin Kubica - 답글
WTF?!? Don’t do this. Buy a replacement battery online, and swap it out. Don’t drill holes, add glue, and try to cram in some battery that isn’t built for it!
fixit4 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 28
30일 전: 146
전체 시간: 28,328
