주요 콘텐츠로 건너뛰기
JD Razor 2000 Handle Bar Replacement
필요한 것
  1. JD Razor 2000 Handle Bar Replacement, Pulling Out the String: 1 단계, 이미지 3개 중 1개 JD Razor 2000 Handle Bar Replacement, Pulling Out the String: 1 단계, 이미지 3개 중 2개 JD Razor 2000 Handle Bar Replacement, Pulling Out the String: 1 단계, 이미지 3개 중 3개
    • Firmly hold the handle bar in place.
    • Grab with one hand the black removable tip of the handle bar and pull it out.
    • Pull out the end of the tied string through the removable tip.
  2. JD Razor 2000 Handle Bar Replacement, Untying the Knot: 2 단계, 이미지 2개 중 1개 JD Razor 2000 Handle Bar Replacement, Untying the Knot: 2 단계, 이미지 2개 중 2개
    • Untie the knot at the end of the string.
    • If you let go of the string while its in tension, it may recoil far into the other side of the handle bars. To avoid this, bring the end of the string inward towards the hollow section of the handle bar and then carefully let it go.
  3. JD Razor 2000 Handle Bar Replacement, Pulling Out the Handlebar: 3 단계, 이미지 2개 중 1개 JD Razor 2000 Handle Bar Replacement, Pulling Out the Handlebar: 3 단계, 이미지 2개 중 2개
    • Press down firmly on the golden fastening button located on the handle bar being replaced.
    • While still pressing down on the fastening button, slide the handle bar apart from the T Bar.
    • When re-installing the handlebar (after completion of the guide), you may need a pair of needle-nosed pliers to thread the string back through the handlebar.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Kevin Church
회원 가입일: 10/16/14
297 평판
안내서 2개를 작성함
Cal Poly, Team 4-46, Amido Fall 2014 Cal Poly, Team 4-46, Amido Fall 2014 회원
CPSU-AMIDO-F14S4G46
4 회원들
안내서 16개를 작성함
3가이드 댓글
Why is the stretchable string for?
dantotford - 답글
Where can I buy a wider set of click in handlebars?
Scooterdad - 답글
I'm also looking for a JD BUG replacement handlebar, I mean the horizontal parts.
Mon Drianus - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 23
전체 시간: 2,556
