주요 콘텐츠로 건너뛰기
JD Razor 2000 Quick-Release Lever Replacement
필요한 것
  1. JD Razor 2000 Quick-Release Lever Replacement, Unlocking the Lever: 1 단계, 이미지 1/2 JD Razor 2000 Quick-Release Lever Replacement, Unlocking the Lever: 1 단계, 이미지 2/2
    • Unlock the quick-release lever by turning the lever from a tightened position.
  2. JD Razor 2000 Quick-Release Lever Replacement, Loosening the Screw: 2 단계, 이미지 1/3 JD Razor 2000 Quick-Release Lever Replacement, Loosening the Screw: 2 단계, 이미지 2/3 JD Razor 2000 Quick-Release Lever Replacement, Loosening the Screw: 2 단계, 이미지 3/3
    • Use a 7/32" Allen Wrench or T25 Screwdriver to loosen the screw shown.
    • Be sure to fasten the opposite side of the screw before unscrewing.
    • Remove the screw and note the order of the parts for reassembly.
  3. JD Razor 2000 Quick-Release Lever Replacement, Removing the Latch: 3 단계, 이미지 1/3 JD Razor 2000 Quick-Release Lever Replacement, Removing the Latch: 3 단계, 이미지 2/3 JD Razor 2000 Quick-Release Lever Replacement, Removing the Latch: 3 단계, 이미지 3/3
    • Turn the quick-release lever over to reveal an 8mm screw.
    • Use the Phillips #2 screw driver to remove the screw.
    • After removing the screw, the circular latch will be detachable.
결론
Shane
회원 가입일: 10/18/14
384 평판
안내서 3개 작성하였습니다
Cal Poly, Team 4-46, Amido Fall 2014 Cal Poly, Team 4-46, Amido Fall 2014 회원
CPSU-AMIDO-F14S4G46
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 13
전체 시간: 2,312
