소개
To complete this guide, you will need to purchase a new battery compartment cover and make sure that you have the tools listed. While it is not necessary to remove the battery to be able to remove the battery cover, it is always good practice to make sure that the device is completely powered off before attempting any repairs.
필요한 것
Remove the two Phillips screws (4mm x 3mm) using the Phillips #00 screwdriver.
다른 한 분이 해당 안내서를 완성하였습니다.
