주요 콘텐츠로 건너뛰기
JVC Adixxion GC-XA1BU Battery Housing Replacement
필요한 것
  1. JVC Adixxion GC-XA1BU Battery Housing Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Find the side of the camera with the black switch shown.
  2. JVC Adixxion GC-XA1BU Battery Housing Replacement: 2 단계, 이미지 1개 중 1개
    • Push down on the black switch.
  3. JVC Adixxion GC-XA1BU Battery Housing Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the battery cover back while pushing down on the black switch.
  4. JVC Adixxion GC-XA1BU Battery Housing Replacement: 4 단계, 이미지 2개 중 1개 JVC Adixxion GC-XA1BU Battery Housing Replacement: 4 단계, 이미지 2개 중 2개
    • Open the battery compartment and push the blue battery release switch.
  5. JVC Adixxion GC-XA1BU Battery Housing Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the battery from the camera.
  6. JVC Adixxion GC-XA1BU Battery Housing Replacement, Battery Cover: 6 단계, 이미지 1개 중 1개
    • Remove the two Phillips screws (4mm x 3mm) using the Phillips #00 screwdriver.
  7. JVC Adixxion GC-XA1BU Battery Housing Replacement, LCD Cover: 7 단계, 이미지 2개 중 1개 JVC Adixxion GC-XA1BU Battery Housing Replacement, LCD Cover: 7 단계, 이미지 2개 중 2개
    • Remove the 8 screws (5mm x 4mm) from the corners of both the front and back of the camera (4 screws on each side) using the T6 Torx screwdriver.
  8. JVC Adixxion GC-XA1BU Battery Housing Replacement: 8 단계, 이미지 1개 중 1개
    • Carefully open the camera as shown and gently peel off the black cover tape.
  9. JVC Adixxion GC-XA1BU Battery Housing Replacement: 9 단계, 이미지 3개 중 1개 JVC Adixxion GC-XA1BU Battery Housing Replacement: 9 단계, 이미지 3개 중 2개 JVC Adixxion GC-XA1BU Battery Housing Replacement: 9 단계, 이미지 3개 중 3개
    • Carefully lift up and remove the cable ribbon clip using the tweezers.
  10. JVC Adixxion GC-XA1BU Battery Housing Replacement: 10 단계, 이미지 2개 중 1개 JVC Adixxion GC-XA1BU Battery Housing Replacement: 10 단계, 이미지 2개 중 2개
    • Carefully grasp and remove the ribbon cable using the tweezers.
  11. JVC Adixxion GC-XA1BU Battery Housing Replacement: 11 단계, 이미지 1개 중 1개
    • Turn the camera as shown and carefully remove the glue from the connector.
  12. JVC Adixxion GC-XA1BU Battery Housing Replacement: 12 단계, 이미지 2개 중 1개 JVC Adixxion GC-XA1BU Battery Housing Replacement: 12 단계, 이미지 2개 중 2개
    • Carefully pull the white clip out of the casing using the tweezers.
  13. JVC Adixxion GC-XA1BU Battery Housing Replacement, Battery Housing: 13 단계, 이미지 2개 중 1개 JVC Adixxion GC-XA1BU Battery Housing Replacement, Battery Housing: 13 단계, 이미지 2개 중 2개
    • Carefully peel off the glue holding the red and black braided wire down to the circuit board.
    • Then remove the connector by gently pulling it out of its casing.
    • You will want to save this glue as it may come in handy when re-assembling your device.
  14. JVC Adixxion GC-XA1BU Battery Housing Replacement: 14 단계, 이미지 2개 중 1개 JVC Adixxion GC-XA1BU Battery Housing Replacement: 14 단계, 이미지 2개 중 2개
    • Lift up the white ribbon clip and remove the black ribbon by gently pulling it away from the white clip.
  15. JVC Adixxion GC-XA1BU Battery Housing Replacement: 15 단계, 이미지 1개 중 1개
    • Remove the the three Phillips screws (3mm headsize x 2mm length) from the circuit board.
    • After you remove the screws, you can then remove the green circuit board by lifting it up out of the device case.
    • You may want to use the plastic opening tool to get start lifting the circuit board.
  16. JVC Adixxion GC-XA1BU Battery Housing Replacement: 16 단계, 이미지 1개 중 1개
    • Once the circuit board is removed, you will want to remove the Phillips screw (3mm headsize x 2 mm length) near the ribbon cable.
    • ONLY REMOVE THIS ONE SCREW.
  17. JVC Adixxion GC-XA1BU Battery Housing Replacement: 17 단계, 이미지 2개 중 1개 JVC Adixxion GC-XA1BU Battery Housing Replacement: 17 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to gently remove the top cover from the camera.
    • It is glued on, so you may need to work at it to get it to come off.
  18. JVC Adixxion GC-XA1BU Battery Housing Replacement: 18 단계, 이미지 1개 중 1개
    • Once the cover has been removed, you will want to remove the three Phillips screws (2mm headsize x 2mm length) that are underneath.
  19. JVC Adixxion GC-XA1BU Battery Housing Replacement: 19 단계, 이미지 2개 중 1개 JVC Adixxion GC-XA1BU Battery Housing Replacement: 19 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Carefully remove both the top and bottom copper strips by gently pulling them off with the tweezers.
  20. JVC Adixxion GC-XA1BU Battery Housing Replacement: 20 단계, 이미지 2개 중 1개 JVC Adixxion GC-XA1BU Battery Housing Replacement: 20 단계, 이미지 2개 중 2개
    • Now you should be able to gently remove the battery housing out of the device.
    • If you are having difficulty getting the battery housing to come out, you may want to use the plastic opening tool to help get it started.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Christina Michelle Johnson
회원 가입일: 01/15/15
1,047 평판
안내서 8개를 작성함
USF Tampa, Team 1-2, Tanski Winter 2015 USF Tampa, Team 1-2, Tanski Winter 2015 회원
USFT-TANSKI-W15S1G2
4 회원들
안내서 8개를 작성함
1가이드 댓글
I couldn't save the glue from the top cover in order to reassembly it. Does this glue has the function to repel the water or its main function is just to glue together the top cover?
Spencer Chedid - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 13
전체 시간: 2,903
