소개
To complete this guide, you will need to purchase a new LCD screen and make sure that you have the tools listed. It is always good practice to make sure that the device is completely powered off and remove the battery before attempting any repairs.
필요한 것
After removing the battery, take out the two Phillips screws (4mm headsize x 3mm length) screws. You can now remove the battery cover.
Using a 1x1xH1.5 torx screwdriver, remove the 8 screws (5mm headsize / 4mm length) from the corners of both the front and back of the camera (4 screws on each side).
Remove the top two Phillips screws (4mm headsize x 3mm length). Now use the tweezers to gently grab and remove the silver metal plate that the screws were holding in place.
다른 한 분이 해당 안내서를 완성하였습니다.
