주요 콘텐츠로 건너뛰기
JVC GR-D290U LCD Screen Replacement
필요한 것
  1. JVC GR-D290U LCD Screen Replacement, LCD Screen: 1 단계, 이미지 1개 중 1개
    • Remove the camera battery. (Not shown.)
    • Remove the 2 screws connecting the back plate to the camera base.
  2. JVC GR-D290U LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the 2 screws on the side opposite the LCD screen.
  3. JVC GR-D290U LCD Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Note: Open the LCD screen for better access to remove the screw. Reclose the screen when finished.
    • Lift up the dark gray tab on the LCD side of the camera and move it aside.
    • Remove the screw under the dark gray tab and then replace the tab.
  4. JVC GR-D290U LCD Screen Replacement: 4 단계, 이미지 2개 중 1개 JVC GR-D290U LCD Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Place a plastic opening tool under the seam of the camera top cover and unsnap the cover.
    • Pull the top cover off of the camera base and set aside.
  5. JVC GR-D290U LCD Screen Replacement: 5 단계, 이미지 2개 중 1개 JVC GR-D290U LCD Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the 2 screws underneath the top cover on the LCD side of the camera.
  6. JVC GR-D290U LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the 5 screws indicated on the bottom plate of the camera.
  7. JVC GR-D290U LCD Screen Replacement: 7 단계, 이미지 2개 중 1개 JVC GR-D290U LCD Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Open the LCD screen and remove the 2 screws at the hinge of the screen.
    • Remove the plastic hinge cover from the camera base.
    • Close the LCD screen when finished.
  8. JVC GR-D290U LCD Screen Replacement: 8 단계, 이미지 2개 중 1개 JVC GR-D290U LCD Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Warning: Avoid detaching the internal wiring by prying the camera apart slowly and carefully.
    • Start from the bottom of the camera. Press and hold the eject button with one hand.
    • Use your other hand to pry the LCD screen cover from the base. Leave the labeled side closed.
  9. JVC GR-D290U LCD Screen Replacement: 9 단계, 이미지 3개 중 1개 JVC GR-D290U LCD Screen Replacement: 9 단계, 이미지 3개 중 2개 JVC GR-D290U LCD Screen Replacement: 9 단계, 이미지 3개 중 3개
    • Detach the white tab from the LCD screen side of the camera by gently tugging at the base of the tab.
    • Put the larger camera base aside.
  10. JVC GR-D290U LCD Screen Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the 3 screws holding the LCD screen hinge to the base.
  11. JVC GR-D290U LCD Screen Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the 2 screws on the green circuit board.
  12. JVC GR-D290U LCD Screen Replacement: 12 단계, 이미지 3개 중 1개 JVC GR-D290U LCD Screen Replacement: 12 단계, 이미지 3개 중 2개 JVC GR-D290U LCD Screen Replacement: 12 단계, 이미지 3개 중 3개
    • Warning: The orange band must stay attached to the circuit board at all times.
    • Remove the L-shaped metal piece from the upper left-hand corner of the circuit board.
    • Remove the circuit board from the cover piece and move it aside with the orange band intact.
  13. JVC GR-D290U LCD Screen Replacement: 13 단계, 이미지 3개 중 1개 JVC GR-D290U LCD Screen Replacement: 13 단계, 이미지 3개 중 2개 JVC GR-D290U LCD Screen Replacement: 13 단계, 이미지 3개 중 3개
    • Open the LCD screen and carefully pull the circuit board through the empty hinge space.
    • Set aside the larger LCD panel.
  14. JVC GR-D290U LCD Screen Replacement: 14 단계, 이미지 3개 중 1개 JVC GR-D290U LCD Screen Replacement: 14 단계, 이미지 3개 중 2개 JVC GR-D290U LCD Screen Replacement: 14 단계, 이미지 3개 중 3개
    • Remove the 2 screws on the hinge side of the LCD screen.
    • Remove the screw at side of the LCD screen.
    • Pull it open with a plastic opening tool and pry it apart.
  15. JVC GR-D290U LCD Screen Replacement: 15 단계, 이미지 3개 중 1개 JVC GR-D290U LCD Screen Replacement: 15 단계, 이미지 3개 중 2개 JVC GR-D290U LCD Screen Replacement: 15 단계, 이미지 3개 중 3개
    • Remove the screw in the circuit board.
    • Pull the LCD screen pack from the frame with the circuit board on top.
    • Detach the LCD screen by firmly grasping the copper tab and gently tugging until the latch unsnaps.
  16. JVC GR-D290U LCD Screen Replacement: 16 단계, 이미지 2개 중 1개 JVC GR-D290U LCD Screen Replacement: 16 단계, 이미지 2개 중 2개
    • Connect the new LCD screen by fitting in the copper attachment site to the thin, black clasp on the circuit board.
    • Fold over the black clasp and snap it into place.
    • Note: You may need to use the plastic opening tool to snap thin black clasp into place.
  17. JVC GR-D290U LCD Screen Replacement: 17 단계, 이미지 3개 중 1개 JVC GR-D290U LCD Screen Replacement: 17 단계, 이미지 3개 중 2개 JVC GR-D290U LCD Screen Replacement: 17 단계, 이미지 3개 중 3개
    • Put the LCD screen into the silver frame and make sure it lies flat. It should line up with the two white plastic brackets.
    • Place the black film frame lined up with the white film into the silver frame. Both should be held in place by tabs.
    • Place the circuit board over the film layers.
    • Screw in the circuit board to the frame.
    • Double-check that the LCD screen lies flat in its frame and reinsert the circuit board screw.
  18. JVC GR-D290U LCD Screen Replacement: 18 단계, 이미지 3개 중 1개 JVC GR-D290U LCD Screen Replacement: 18 단계, 이미지 3개 중 2개 JVC GR-D290U LCD Screen Replacement: 18 단계, 이미지 3개 중 3개
    • Before reattaching the LCD screen lid, make sure the silver hinge piece is inserted in the slot next to the circuit board.
    • Replace the loose orange band in the slot on the hinge side of the LCD screen.
    • Snap the LCD screen lid back in place starting at the side opposite the hinge.
  19. JVC GR-D290U LCD Screen Replacement: 19 단계, 이미지 2개 중 1개 JVC GR-D290U LCD Screen Replacement: 19 단계, 이미지 2개 중 2개
    • Reinsert the shortest of the 3 screws on the top of the screen cover opposite of the hinge.
    • Reinsert the 2 remaining screws on the hinge side of the LCD screen.
  20. JVC GR-D290U LCD Screen Replacement: 20 단계, 이미지 3개 중 1개 JVC GR-D290U LCD Screen Replacement: 20 단계, 이미지 3개 중 2개 JVC GR-D290U LCD Screen Replacement: 20 단계, 이미지 3개 중 3개
    • Place the loose circuit board back through the empty hinge space.
    • Line up the LCD screen in slot on the camera base and snap it into place.
    • Reinsert the 3 screws along the orange band to hold the LCD screen onto the entire panel.
  21. JVC GR-D290U LCD Screen Replacement: 21 단계, 이미지 3개 중 1개 JVC GR-D290U LCD Screen Replacement: 21 단계, 이미지 3개 중 2개 JVC GR-D290U LCD Screen Replacement: 21 단계, 이미지 3개 중 3개
    • Reinsert the circuit board into the slot. Make sure to lock it securely under the tabs.
    • Reinsert the L-shaped metal piece into its slot. Line it up with the screw hole and the protruding place holder.
    • Reinsert the 2 screws in the circuit board with the longer screw holding the L-shaped metal piece in place.
  22. JVC GR-D290U LCD Screen Replacement: 22 단계, 이미지 3개 중 1개 JVC GR-D290U LCD Screen Replacement: 22 단계, 이미지 3개 중 2개 JVC GR-D290U LCD Screen Replacement: 22 단계, 이미지 3개 중 3개
    • Reattach the white tab by placing it under the thin, black slot and snap it back into place.
    • Carefully line up the bottom of the LCD panel and the camera base, then snap it back into place.
  23. JVC GR-D290U LCD Screen Replacement: 23 단계, 이미지 3개 중 1개 JVC GR-D290U LCD Screen Replacement: 23 단계, 이미지 3개 중 2개 JVC GR-D290U LCD Screen Replacement: 23 단계, 이미지 3개 중 3개
    • Reinsert the LCD screen hinge and screw in the 2 screws to hold it in place
    • Reinsert the 5 screws on the bottom panel of the camera. The shortest screw needs to be put into the hole with the arrow pointing to it.
  24. JVC GR-D290U LCD Screen Replacement: 24 단계, 이미지 3개 중 1개 JVC GR-D290U LCD Screen Replacement: 24 단계, 이미지 3개 중 2개 JVC GR-D290U LCD Screen Replacement: 24 단계, 이미지 3개 중 3개
    • Reinsert the 2 screws under the top cover of the LCD side of the camera.
    • Move the dark grey tab to ensure that the top cover is not damaged.
    • Line up the top cover on the camera base and then snap it back into place.
  25. JVC GR-D290U LCD Screen Replacement: 25 단계, 이미지 2개 중 1개 JVC GR-D290U LCD Screen Replacement: 25 단계, 이미지 2개 중 2개
    • Reinsert the screw under the dark, grey tab on the LCD side of the camera and replace tab.
    • Reinsert the 2 screws on the side of the camera opposite of the LCD screen.
  26. JVC GR-D290U LCD Screen Replacement: 26 단계, 이미지 1개 중 1개
    • Reinsert the 2 screws connecting the back plate to the camera base.
    • Reinsert the battery.
    • Turn it on and test functionality.
결승점
작성자
14다른 기여자 명과 함께
justin chen
회원 가입일: 04/27/10
47 평판
안내서 3개를 작성함
Cal Poly, Team 18-69, Johann Spring 2010 Cal Poly, Team 18-69, Johann Spring 2010 회원
CPSU-JOHANN-S10S18G69
4 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 22
전체 시간: 5,215
