주요 콘텐츠로 건너뛰기
JVC GR-D72U Lateral Function Port Panel Replacement
필요한 것
  1. JVC GR-D72U Lateral Function Port Panel Replacement, Battery: 1 단계, 이미지 2개 중 1개 JVC GR-D72U Lateral Function Port Panel Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Locate button on bottom of camera.
    • Slide button to the right.
  2. JVC GR-D72U Lateral Function Port Panel Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the battery towards the bottom of the camcorder while lifting battery .
  3. JVC GR-D72U Lateral Function Port Panel Replacement, Lateral Function Port Panel: 3 단계, 이미지 3개 중 1개 JVC GR-D72U Lateral Function Port Panel Replacement, Lateral Function Port Panel: 3 단계, 이미지 3개 중 2개 JVC GR-D72U Lateral Function Port Panel Replacement, Lateral Function Port Panel: 3 단계, 이미지 3개 중 3개
    • Remove silver plate that says “Auto Light” on the top of the camera using a metal spudger.
    • Remove the 3.1 mm screw.
    • Remove the three 5.3 mm screws from the back of the camera.
  4. JVC GR-D72U Lateral Function Port Panel Replacement: 4 단계, 이미지 1개 중 1개
    • From the bottom of the camera remove the following four screws:
    • 5.3 mm
    • 3.1 mm
    • 5.1 mm
    • 3.5 mm
  5. JVC GR-D72U Lateral Function Port Panel Replacement: 5 단계, 이미지 1개 중 1개
    • Use the small plastic opening tool to remove the blue side cover piece.
  6. JVC GR-D72U Lateral Function Port Panel Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the 3.1 mm screw on top of the camera, closest to the LCD monitor.
    • Remove the 5.4 mm screw next to the snapshot button.
  7. JVC GR-D72U Lateral Function Port Panel Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the 3.1 mm screw next to the USB and DV inputs.
  8. JVC GR-D72U Lateral Function Port Panel Replacement: 8 단계, 이미지 1개 중 1개
    • Gently pull apart both halves of the camera to reveal the inner components.
  9. JVC GR-D72U Lateral Function Port Panel Replacement: 9 단계, 이미지 3개 중 1개 JVC GR-D72U Lateral Function Port Panel Replacement: 9 단계, 이미지 3개 중 2개 JVC GR-D72U Lateral Function Port Panel Replacement: 9 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Flip the cable locks to the up-position and pull both cables connecting the lateral function port panel to the rest of the camera.
    • Insert the cables from the new port panel into their inputs and flip the locks to the down position.
    • It is easier to use tweezers when inserting the cable but not required.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Joshua Hatcherian
회원 가입일: 09/28/17
194 평판
안내서 1개를 작성함
USF Tampa, Team S2-G2, Nance Fall 2017 USF Tampa, Team S2-G2, Nance Fall 2017 회원
USFT-NANCE-F17S2G2
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 12
전체 시간: 672
