주요 콘텐츠로 건너뛰기
JVC GR-D93U Eye Piece Replacement
필요한 것
  1. JVC GR-D93U Eye Piece Replacement, Eye Piece: 1 단계, 이미지 1/2 JVC GR-D93U Eye Piece Replacement, Eye Piece: 1 단계, 이미지 2/2
    • Unscrew two 3mm Phillips #0 screw from the bottom of the camera to remove blue plastic casing.
  2. JVC GR-D93U Eye Piece Replacement: 2 단계, 이미지 1/2 JVC GR-D93U Eye Piece Replacement: 2 단계, 이미지 2/2
    • Unscrew two 3mm Phillips #0 screws. Then remove 6 3mm Philips #0 screws from the bottom of the camera.
  3. JVC GR-D93U Eye Piece Replacement: 3 단계, 이미지 1/1
    • Unscrew 3mm Phillips #0 screws from the batter port under the eye piece.
  4. JVC GR-D93U Eye Piece Replacement: 4 단계, 이미지 1/2 JVC GR-D93U Eye Piece Replacement: 4 단계, 이미지 2/2
    • Now the camera can be split into two pieces. Be careful when removing the two sides and remove the cables connecting the two halves. There are also cables that need to be disconnected from the battery pack section.
  5. JVC GR-D93U Eye Piece Replacement: 5 단계, 이미지 1/3 JVC GR-D93U Eye Piece Replacement: 5 단계, 이미지 2/3 JVC GR-D93U Eye Piece Replacement: 5 단계, 이미지 3/3
    • Unscrew two 3mm Phillips #0 screws from around the eye piece. Then flip the camera over and unscrew 3mm Phillips #0 screw. Then unscrew 3mm Phillips #0 screw from under the eye piece.
  6. JVC GR-D93U Eye Piece Replacement: 6 단계, 이미지 1/2 JVC GR-D93U Eye Piece Replacement: 6 단계, 이미지 2/2
    • Unscrew 3mm Phillips #0 screw and disconnect cable. This will disconnect the eye piece from the camera.
결론
Lindsay
회원 가입일: 03/16/15
267 평판
안내서 2개 작성하였습니다
Colorado Springs, Team 1-5, May Spring 2015 Colorado Springs, Team 1-5, May Spring 2015 회원
UCCS-MAY-S15S1G5
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 11
전체 시간: 292
