주요 콘텐츠로 건너뛰기
JVC KW-V820BT Driver Side Panel Removal and Replacement
필요한 것
  1. JVC KW-V820BT Driver Side Panel Removal and Replacement, Front Panel Assembly: 1 단계, 이미지 1/3 JVC KW-V820BT Driver Side Panel Removal and Replacement, Front Panel Assembly: 1 단계, 이미지 2/3 JVC KW-V820BT Driver Side Panel Removal and Replacement, Front Panel Assembly: 1 단계, 이미지 3/3
    • Remove the four 1/8-inch black machine screws using a Phillips #00 screwdriver.
  2. JVC KW-V820BT Driver Side Panel Removal and Replacement: 2 단계, 이미지 1/2 JVC KW-V820BT Driver Side Panel Removal and Replacement: 2 단계, 이미지 2/2
    • Remove three steel-finish, pan-head, 1/64 x 3/16" machine screws identified in the photograph, using the Phillips #0 screwdriver.
  3. JVC KW-V820BT Driver Side Panel Removal and Replacement: 3 단계, 이미지 1/3 JVC KW-V820BT Driver Side Panel Removal and Replacement: 3 단계, 이미지 2/3 JVC KW-V820BT Driver Side Panel Removal and Replacement: 3 단계, 이미지 3/3
    • Using your fingers and/or a metal spudger, gently release the plastic locking tabs of the front panel assembly from the steel enclosure while prying the front panel assembly away from the steel enclosure with your fingers.
  4. JVC KW-V820BT Driver Side Panel Removal and Replacement: 4 단계, 이미지 1/1
    • Gently remove the front panel from the steel enclosure.
  5. JVC KW-V820BT Driver Side Panel Removal and Replacement: 5 단계, 이미지 1/3 JVC KW-V820BT Driver Side Panel Removal and Replacement: 5 단계, 이미지 2/3 JVC KW-V820BT Driver Side Panel Removal and Replacement: 5 단계, 이미지 3/3
    • Gently separate the ribbon cable from from ZIF connector on the circuit board using a metal smudger.
    • Be careful not to scratch or damage components or features of the circuit board with the metal spudger
  6. JVC KW-V820BT Driver Side Panel Removal and Replacement, Top Panel Removal: 6 단계, 이미지 1/3 JVC KW-V820BT Driver Side Panel Removal and Replacement, Top Panel Removal: 6 단계, 이미지 2/3 JVC KW-V820BT Driver Side Panel Removal and Replacement, Top Panel Removal: 6 단계, 이미지 3/3
    • Remove seven 1/64 x 3/16" screws from the top panel using the Phillips #0 screwdriver.
    • Remove the top panel.
  7. JVC KW-V820BT Driver Side Panel Removal and Replacement, Disc Drive: 7 단계, 이미지 1/1
    • After removing all screws and top panel, lift up disc drive from steel enclosure.
  8. JVC KW-V820BT Driver Side Panel Removal and Replacement: 8 단계, 이미지 1/1
    • Turn over the disc drive to expose the connector.
    • Gently remove the ribbon cable from the ZIF on the circuit board using the metal spudger.
  9. JVC KW-V820BT Driver Side Panel Removal and Replacement: 9 단계, 이미지 1/3 JVC KW-V820BT Driver Side Panel Removal and Replacement: 9 단계, 이미지 2/3 JVC KW-V820BT Driver Side Panel Removal and Replacement: 9 단계, 이미지 3/3
    • Gently pull to remove the electrical connector from disc drive.
  10. JVC KW-V820BT Driver Side Panel Removal and Replacement: 10 단계, 이미지 1/2 JVC KW-V820BT Driver Side Panel Removal and Replacement: 10 단계, 이미지 2/2
    • Remove 2 pan-head, 1/64 x 3/16" machine screws using a Phillips #0 screwdriver.
  11. JVC KW-V820BT Driver Side Panel Removal and Replacement: 11 단계, 이미지 1/2 JVC KW-V820BT Driver Side Panel Removal and Replacement: 11 단계, 이미지 2/2
  12. JVC KW-V820BT Driver Side Panel Removal and Replacement, Driver Side Panel Removal and: 12 단계, 이미지 1/3 JVC KW-V820BT Driver Side Panel Removal and Replacement, Driver Side Panel Removal and: 12 단계, 이미지 2/3 JVC KW-V820BT Driver Side Panel Removal and Replacement, Driver Side Panel Removal and: 12 단계, 이미지 3/3
    • Remove the six pan-head, 1/64 x 3/16" machine screws using a Phillips #0 screwdriver.
결론
Marshall Andersen
회원 가입일: 10/02/18
665 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 180
