주요 콘텐츠로 건너뛰기
Jabra Elite 85h Bluetooth Module Replacement
필요한 것
  1. Jabra Elite 85h Bluetooth Module Replacement, Bluetooth Module: 1 단계, 이미지 1/3 Jabra Elite 85h Bluetooth Module Replacement, Bluetooth Module: 1 단계, 이미지 2/3 Jabra Elite 85h Bluetooth Module Replacement, Bluetooth Module: 1 단계, 이미지 3/3
    • Remove each ear cushion by hooking your fingers along the inside of the ear cushion and pulling up and away from the ear cup.
    • If the cushion does not fully release, move your hand to the opposite side and pull up inn the same manner.
  2. Jabra Elite 85h Bluetooth Module Replacement: 2 단계, 이미지 1/3 Jabra Elite 85h Bluetooth Module Replacement: 2 단계, 이미지 2/3 Jabra Elite 85h Bluetooth Module Replacement: 2 단계, 이미지 3/3
    • The foam inserts and backing tape are very delicate, take your time when removing them and be careful to not rip or tear the material.
    • Using the small plastic spudger to assist, begin lifting up and removing the foam inserts with attached backing tape.
  3. Jabra Elite 85h Bluetooth Module Replacement: 3 단계, 이미지 1/3 Jabra Elite 85h Bluetooth Module Replacement: 3 단계, 이미지 2/3 Jabra Elite 85h Bluetooth Module Replacement: 3 단계, 이미지 3/3
    • Repeat previous steps on other side.
  4. Jabra Elite 85h Bluetooth Module Replacement: 4 단계, 이미지 1/1
    • Unscrew and remove the four T6 screws holding the speaker in place.
  5. Jabra Elite 85h Bluetooth Module Replacement: 5 단계, 이미지 1/1
    • Tilt the headphones over so that the speaker tilts out of the plastic holder.
    • Repeat for both sides.
  6. Jabra Elite 85h Bluetooth Module Replacement: 6 단계, 이미지 1/2 Jabra Elite 85h Bluetooth Module Replacement: 6 단계, 이미지 2/2
    • Remove the two screws holding the upper and lower circuit boards in place.
  7. Jabra Elite 85h Bluetooth Module Replacement: 7 단계, 이미지 1/2 Jabra Elite 85h Bluetooth Module Replacement: 7 단계, 이미지 2/2
    • Remove the two attached circuit boards from the headphone housing.
    • De-solder Bluetooth Module from control board to replace.
결론
Ryan Callaghan
회원 가입일: 03/13/23
725 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 3-4, Petersen Spring 2023 UMass Dartmouth, Team 3-4, Petersen Spring 2023 회원
UMASSD-PETERSEN-S23S3G4
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 21
30일 전: 74
전체 시간: 1,403
