소개
If you are having problems with the audio output from one or both speakers on this headset, you may need to replace the speakers. Follow this guide to correctly disassemble the headset and replace the speakers. This guide shows the steps for only one side, but the process is identical for both speakers.
필요한 것
Remove each ear cushion by hooking your fingers along the inside of the ear cushion and pulling up and away from the ear cup.
If the cushion does not fully release, move your hand to the opposite side and pull up inn the same manner.
Using the small plastic spudger to assist, begin lifting up and removing the foam inserts with attached backing tape.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 3개
Thanks a lot man, I was having some issues with my left side for a while. I assumed it was bad connection since it would return depending on the position and sometimes on non-ANC setup. I just tightened those screws and now it works fine. Cheers.
Hi, doughter overturned the speaker. Now the device no longer switches on. can this be fixed again?
Thanks fit your Help.
Regards
Where can I get replacement speakers. I know it is 40mm in diameter but what is the ohm and other specifications?
Çağdaş Son - 답글
