주요 콘텐츠로 건너뛰기
Jabra Freeway Speaker Replacement
필요한 것
  1. Jabra Freeway Speaker Replacement, Front Panel: 1 단계, 이미지 1/3 Jabra Freeway Speaker Replacement, Front Panel: 1 단계, 이미지 2/3 Jabra Freeway Speaker Replacement, Front Panel: 1 단계, 이미지 3/3
    • Turn off the device before proceeding. Failure to do so may result in device damage or injury to oneself.
    • Remove the rubber pads from the bottom of the device using the spudger.
  2. Jabra Freeway Speaker Replacement: 2 단계, 이미지 1/3 Jabra Freeway Speaker Replacement: 2 단계, 이미지 2/3 Jabra Freeway Speaker Replacement: 2 단계, 이미지 3/3
    • Remove the eight 6mm T9 screws.
    • Two of these screws are underneath the foam padding. This padding is glued on and will be destroyed in this process. Poking through the foam minimizes the damage to the device.
  3. Jabra Freeway Speaker Replacement: 3 단계, 이미지 1/3 Jabra Freeway Speaker Replacement: 3 단계, 이미지 2/3 Jabra Freeway Speaker Replacement: 3 단계, 이미지 3/3
    • Gently lift the front panel off of the device and carefully rest it to the side.
  4. Jabra Freeway Speaker Replacement, Speaker: 4 단계, 이미지 1/2 Jabra Freeway Speaker Replacement, Speaker: 4 단계, 이미지 2/2
    • Gently lift the speaker out of the device using the spudger.
    • The speaker is not fixed in place, and therefore very little force is necessary to remove this component.
  5. Jabra Freeway Speaker Replacement: 5 단계, 이미지 1/1
    • Desolder the two wires connecting to the speaker.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alec Wilson
회원 가입일: 10/19/16
741 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 4-8, Catania Fall 2016 UMass Dartmouth, Team 4-8, Catania Fall 2016 회원
UMASSD-CATANIA-F16S4G8
2 회원들
안내서 6개 작성하였습니다
댓글 한 개
This guide is missing something. It is titled Speaker Replacement not just removal. Useful information to complete the replacement of a faulty speaker would include where to find a replacement part or at least a part number to search for. Removing the speaker without replacing it with another is of little use. But thank you for your time and effort.
Jssamp - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 13
전체 시간: 980
