소개
If the speaker is distorted or not functioning, you may need to replace it. This guide will give you step-by-step instructions on how to replace the speaker in the Jabra Speak 510.
  1. Using a metal spudger, peel back the foam pad on the bottom of the device to reveal six screws. Using a metal spudger, peel back the foam pad on the bottom of the device to reveal six screws.
    • Using a metal spudger, peel back the foam pad on the bottom of the device to reveal six screws.
  2. Remove the six 20 mm T6 screws from the bottom of the device.
    • Remove the six 20 mm T6 screws from the bottom of the device.
    Remove the screws using T6 Torx screwdriver.
    Taha Asad - 답글
  3. 안드로이드 수리 키트
    새 스크린 혹은 배터리는 단 하나의 키트로 충분합니다.
    지금 장보기
    안드로이드 수리 키트
    지금 장보기
  4. Remove the back plate and the grey foam underneath. Remove the back plate and the grey foam underneath.
    • Remove the back plate and the grey foam underneath.
  5. Use a small, pointed metal spudger to  release the plastic tabs connecting the faceplate to the bottom of the speaker. A small cable connects the faceplate to the device. Carefully disconnect the cable before fully opening  the device. Slowly flip the device open like a clam shell.
    • Use a small, pointed metal spudger to release the plastic tabs connecting the faceplate to the bottom of the speaker.
    • A small cable connects the faceplate to the device. Carefully disconnect the cable before fully opening the device.
    • Slowly flip the device open like a clam shell.
    • There are several wires soldered to the motherboard that prevent the faceplate from detaching completely.
  6. Desolder the two wires running to the speaker. You can find soldering tips in the How To Solder and Desolder Connections guide.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jordan Murphy
회원 가입일: 2016년 02월 16일
510 Reputation
안내서 3개 작성하였습니다
IUPUI, Team 2-3, Harley Spring 2016 IUPUI, Team 2-3, Harley Spring 2016 회원
IUPUI-HARLEY-S16S2G3
4 회원들
안내서 4개 작성하였습니다
댓글 한 개
soleniall buen aporteee
bryanpinedaza - 답글
댓글 쓰기
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 30
All Time: 1,836
