주요 콘텐츠로 건너뛰기
Jam Voice Motherboard Replacement
필요한 것
  1. Jam Voice Motherboard  Replacement, Hard Mesh Cover: 1 단계, 이미지 1/2 Jam Voice Motherboard  Replacement, Hard Mesh Cover: 1 단계, 이미지 2/2
    • Insert the plastic opening tool underneath the mesh top.
    • Pry the cover open.
    • To reattach the cover, simply align the round posts on the bottom of the cover into the holes.
  2. Jam Voice Motherboard  Replacement, Motherboard: 2 단계, 이미지 1/1
    • Remove the four 7mm Phillips screws from the plastic cover.
  3. Jam Voice Motherboard  Replacement: 3 단계, 이미지 1/2 Jam Voice Motherboard  Replacement: 3 단계, 이미지 2/2
    • Remove the four 5mm Phillips screws that hold down the speaker in place.
    • Remove the two 6mm Phillips screws that hold down the plastic casing.
  4. Jam Voice Motherboard  Replacement: 4 단계, 이미지 1/1
    • Once all six screws are removed, use a Halberd Spudger or similar tool to lift up the speaker.
    • Pull the speaker up and out.
  5. Jam Voice Motherboard  Replacement: 5 단계, 이미지 1/3 Jam Voice Motherboard  Replacement: 5 단계, 이미지 2/3 Jam Voice Motherboard  Replacement: 5 단계, 이미지 3/3
    • Remove the four 7mm Phillips screws to expose the motherboard.
  6. Jam Voice Motherboard  Replacement: 6 단계, 이미지 1/1
    • After removing all of the screws from the plastic cover, remove it by pulling up and out.
    • Be careful not to pull and damage any of the wires.
  7. Jam Voice Motherboard  Replacement: 7 단계, 이미지 1/2 Jam Voice Motherboard  Replacement: 7 단계, 이미지 2/2
    • Remove the three 5mm Phillips screws that hold the motherboard in place.
    • After the screws are removed, place two fingers on the power button and Bluetooth button to push the motherboard out.
결론
Hope Bukhamseen
회원 가입일: 04/05/18
298 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 8
전체 시간: 222
