필요한 것
Remove the screws for the speaker and the four that are down the holes.
It isn't necessary but I removed the d-ring as well.
They used black silicone to keep the connectors together so the entire assembly may come off. I suggest making sure you know how the go back together.
Carefully using a knife try to split the silicone so the connectors come off easily.
Next remove the fours screws holding the board in. (Note: There is two matching pairs.)
Using the spudger remove the battery from the white plastic.
거의 끝나갑니다!
결론
