주요 콘텐츠로 건너뛰기
Jam XT HX-P430 Disassembly
필요한 것
  1. Jam XT HX-P430 Disassembly, Casing: 1 단계, 이미지 1/1
    • You can really take this off however you want but here's a pic.
  2. Jam XT HX-P430 Disassembly, Speaker Guard: 2 단계, 이미지 1/3 Jam XT HX-P430 Disassembly, Speaker Guard: 2 단계, 이미지 2/3 Jam XT HX-P430 Disassembly, Speaker Guard: 2 단계, 이미지 3/3
    • Using a spudger or similar pry the guard off one side at a time.
  3. Jam XT HX-P430 Disassembly, Screws!: 3 단계, 이미지 1/2 Jam XT HX-P430 Disassembly, Screws!: 3 단계, 이미지 2/2
    • Remove the screws for the speaker and the four that are down the holes.
    • It isn't necessary but I removed the d-ring as well.
  4. Jam XT HX-P430 Disassembly, Case: 4 단계, 이미지 1/3 Jam XT HX-P430 Disassembly, Case: 4 단계, 이미지 2/3 Jam XT HX-P430 Disassembly, Case: 4 단계, 이미지 3/3
    • Remove the black button spacers. (Note: There are 3 spacers I lost one).
    • Push the white bottom through the hole and slowly wiggle the blue case off. Be careful not to break the speaker cables.
    • Now remove the four screws.
  5. Jam XT HX-P430 Disassembly, Board and Battery.: 5 단계, 이미지 1/3 Jam XT HX-P430 Disassembly, Board and Battery.: 5 단계, 이미지 2/3 Jam XT HX-P430 Disassembly, Board and Battery.: 5 단계, 이미지 3/3
    • They used black silicone to keep the connectors together so the entire assembly may come off. I suggest making sure you know how the go back together.
    • Carefully using a knife try to split the silicone so the connectors come off easily.
    • Next remove the fours screws holding the board in. (Note: There is two matching pairs.)
    • Using the spudger remove the battery from the white plastic.
  6. Jam XT HX-P430 Disassembly, Finished!: 6 단계, 이미지 1/2 Jam XT HX-P430 Disassembly, Finished!: 6 단계, 이미지 2/2
    • Yay! It is disassembled.
    • (Note: There are 3 spacers I lost one).
결론
Wolf Andrew
회원 가입일: 03/19/18
133 평판
안내서 1개 작성함
댓글 한 개
Is the amp bridgable ?
jonathan s - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 717
