주요 콘텐츠로 건너뛰기
Jawbone Big Jambox Auxiliary Board Replacement
필요한 것
  1. Jawbone Big Jambox Auxiliary Board Replacement, Auxiliary Board: 1 단계, 이미지 1/1
    • Remove both end caps by putting a plastic opening tool in the center of the seam. Work around the edges to pry the end caps off completely.
  2. Jawbone Big Jambox Auxiliary Board Replacement: 2 단계, 이미지 1/1
    • Peel the indicated rubber tabs off, at the bottom of the speaker, using a plastic opening tool if necessary.
    • Unscrew indicated T6 9.7 mm screws.
  3. Jawbone Big Jambox Auxiliary Board Replacement: 3 단계, 이미지 1/1
    • Place the Jambox with the left end cap facing upward. There’s 4 screws need to take off.
  4. Jawbone Big Jambox Auxiliary Board Replacement: 4 단계, 이미지 1/1
    • With the side cap removed, pry open the bottom panel by letting up.
    • Pull the bottom up. This may take a bit of force as the bottom is glued to device.
    • Once removed, the battery is now visible.
  5. Jawbone Big Jambox Auxiliary Board Replacement: 5 단계, 이미지 1/1
    • Before unscrewing, take a picture of the top view. That way, when you're reassembling the device, you'll know the orientation of the metal grounding plates.
    • Unscrew the eight indicated T6 9.8 mm screws. Remove metal grounding plates.
  6. Jawbone Big Jambox Auxiliary Board Replacement: 6 단계, 이미지 1/1
    • Once all eight screws are removed, pry the sides of the Jambox to lift the body from it's shell.
  7. Jawbone Big Jambox Auxiliary Board Replacement: 7 단계, 이미지 1/1
    • With the battery facing forward, remove the three indicated T6 9.5 mm screws.
    • Once the screws are removed, lift up the small plastic plate, revealing the auxiliary board underneath.
  8. Jawbone Big Jambox Auxiliary Board Replacement: 8 단계, 이미지 1/1
    • Turn the Jambox so that the button panel is visible.
    • Remove the indicated screws, T6 9.6 mm.
  9. Jawbone Big Jambox Auxiliary Board Replacement: 9 단계, 이미지 1/1
    • Remove the button panel.
  10. Jawbone Big Jambox Auxiliary Board Replacement: 10 단계, 이미지 1/1
    • Remove the colored ribbon that connects the green button circuit board to the blue auxiliary board by using your finger to lift the small black tabs that clamp down the ribbon.
  11. Jawbone Big Jambox Auxiliary Board Replacement: 11 단계, 이미지 1/1
    • Remove the indicated T6 7.4 mm screw holding the auxiliary board in place.
  12. Jawbone Big Jambox Auxiliary Board Replacement: 12 단계, 이미지 1/1
    • Remove the auxiliary board and replace.
    • Repeat steps in reverse order to assemble.
결론
Pictures where referenced from previous guides.
다른 2명이 해당 안내서를 완성하였습니다.
Daniel Leon-Gijon
회원 가입일: 11/27/18
265 평판
안내서 1개 작성함
댓글 7개
Where can you get a replacement aux board? Or specific components on it? (My bluetooth pairing switch seems not to work, everything else seems fine.)
Mike Harris - 답글
Donde puedo encintrar toda la parte completa para remplazarla
Charly Pera - 답글
Como puedo comprar toda parte completa de donde entra la carga ala spearck jawbone big jambox
Charly Pera - 답글
Ou puis je acheter la platine auxiliaire?
Bravo pour le Tuto
Vincent - 답글
где купить эту гребаную микросхему? как поменять это и дураку понятно.
volozhaev - 답글
Hi I need someone to Fixit my jambox
Thulani - 답글
where can i buy the Auxiliary Board?
zj.awp - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 21
전체 시간: 1,848
