소개
Step-by-step guide to take apart Jawbone Big Jambox to expose the inside guts for certain part replacements. This guide will require unscrewing and prying at the device.
필요한 것
Remove both end caps by putting a plastic opening tool in the center of the seam. Work around the edges to pry the end caps off completely.
With the Jawbone logo facing towards you and with correct orientation, place the Jambox with the left end cap facing upward.
Unscrew indicated T6 9.7 mm screws.
Gently loosen the tabs from their anchor points so the bottom may be removed.
Flip the Jambox so the other end cap is facing up. The USB cable is on this side (metal grounding clip, indicated in orange). Repeat the above two steps.
다른 한 분이 해당 안내서를 완성하였습니다.
