주요 콘텐츠로 건너뛰기
소개
Step-by-step guide to take apart Jawbone Big Jambox to expose the inside guts for certain part replacements. This guide will require unscrewing and prying at the device.
부품
지정된 부품이 없습니다.
  1. Remove both end caps by putting a plastic opening tool in the center of the seam. Work around the edges to pry the end caps off completely.
    • Remove both end caps by putting a plastic opening tool in the center of the seam. Work around the edges to pry the end caps off completely.
    • Due to interior clips holding the end caps in place, use caution when applying force.
  2. Turn the Jambox upside down. Peel the indicated rubber tabs off, using a plastic opening tool if necessary. You may want to only take the tabs half way off to avoid re-gluing when reassembling. Remove the three T6, 7.0 mm screws under each rubber tab.
    • Turn the Jambox upside down. Peel the indicated rubber tabs off, using a plastic opening tool if necessary.
    • You may want to only take the tabs half way off to avoid re-gluing when reassembling.
    • Remove the three T6, 7.0 mm screws under each rubber tab.
    • Because the screws are a different length, set the screws aside.
  3. With the Jawbone logo facing towards you and with correct orientation, place the Jambox with the left end cap facing upward. Unscrew indicated T6 9.7 mm screws. Gently loosen the tabs from their anchor points so the bottom may be removed.
    • With the Jawbone logo facing towards you and with correct orientation, place the Jambox with the left end cap facing upward.
    • Unscrew indicated T6 9.7 mm screws.
    • Gently loosen the tabs from their anchor points so the bottom may be removed.
    • Flip the Jambox so the other end cap is facing up. The USB cable is on this side (metal grounding clip, indicated in orange). Repeat the above two steps.
  4. Pry up the bottom panel by lifting from the device.
    • Pry up the bottom panel by lifting from the device.
    • Pull the bottom up. This may take a bit of force as the bottom is glued to device.
    • Once removed, the battery will now be visible.
  5. Before unscrewing, take a picture of the top view. That way, when you're reassembling the device, you'll know the orientation of the metal grounding plates. Unscrew the eight indicated T6 9.8 mm screws. Remove metal grounding plates.
    • Before unscrewing, take a picture of the top view. That way, when you're reassembling the device, you'll know the orientation of the metal grounding plates.
    • Unscrew the eight indicated T6 9.8 mm screws. Remove metal grounding plates.
  6. Once all eight screws are removed, pry the sides of the Jambox to lift the body from it's shell.
    • Once all eight screws are removed, pry the sides of the Jambox to lift the body from it's shell.
  7. With the battery facing forward, remove the three indicated T6 9.5 mm screws.
    • With the battery facing forward, remove the three indicated T6 9.5 mm screws.
    • Once the screws are removed, lift up the small plastic plate, revealing the auxiliary board underneath.
결론
Abby Cybula
회원 가입일: 2015년 04월 01일
1,571 평판
안내서 2개 작성하였습니다
Cal Poly, Team 24-5, Lancaster Spring 2015 Cal Poly, Team 24-5, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S24G5
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 253
