주요 콘텐츠로 건너뛰기
Jazz Digi-Stix JDC11 Case Replacement
필요한 것
  1. Jazz Digi-Stix JDC11 Case Replacement, Battery: 1 단계, 이미지 2개 중 1개 Jazz Digi-Stix JDC11 Case Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Flip the device so that the bottom is facing upwards. Using thumb, push the tab on the bottom in the direction indicated by the arrow and then lift the unhinged part of the tab.
  2. Jazz Digi-Stix JDC11 Case Replacement: 2 단계, 이미지 1개 중 1개
    • Tilt device so that batteries slide out.
  3. Jazz Digi-Stix JDC11 Case Replacement, Capture Button: 3 단계, 이미지 3개 중 1개 Jazz Digi-Stix JDC11 Case Replacement, Capture Button: 3 단계, 이미지 3개 중 2개 Jazz Digi-Stix JDC11 Case Replacement, Capture Button: 3 단계, 이미지 3개 중 3개
    • Carefully insert the flat end of the spudger into the seam on the top side of the device. Carefully twist the spudger to open the device. Repeat this step at incremental locations around the seam of the device until the two case halves separate.
    • Before completely separating the two halves, separate the case from the battery compartment cover, pulling the case apart. Take care not to break the plastic hinge as the battery compartment cover is removed.
  4. Jazz Digi-Stix JDC11 Case Replacement: 4 단계, 이미지 3개 중 1개 Jazz Digi-Stix JDC11 Case Replacement: 4 단계, 이미지 3개 중 2개 Jazz Digi-Stix JDC11 Case Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • There are two wires (one red and one black) that could get disconnected from the motherboard when prying the case apart.
    • Gently seperate the two halves of the device.
    • To remove the circuit board from the right section of the device, unscrew the two 5.6 mm Phillips #00 screws.
    • When the screws have been fully unscrewed, use the tweezers to remove them from the device.
  5. Jazz Digi-Stix JDC11 Case Replacement: 5 단계, 이미지 1개 중 1개
    • Carefully separate the grey side bar from the case and set it aside.
  6. Jazz Digi-Stix JDC11 Case Replacement: 6 단계, 이미지 1개 중 1개
    • Use the tweezers to grasp the bottom of the capture button. Pull the capture button away from the case and set it aside.
  7. Jazz Digi-Stix JDC11 Case Replacement, Board/Microphone/Battery Compartment: 7 단계, 이미지 3개 중 1개 Jazz Digi-Stix JDC11 Case Replacement, Board/Microphone/Battery Compartment: 7 단계, 이미지 3개 중 2개 Jazz Digi-Stix JDC11 Case Replacement, Board/Microphone/Battery Compartment: 7 단계, 이미지 3개 중 3개
    • To remove the microphone from the case, insert the tip of the spudger under the microphone's edge and pry it away from the case.
  8. Jazz Digi-Stix JDC11 Case Replacement: 8 단계, 이미지 3개 중 1개 Jazz Digi-Stix JDC11 Case Replacement: 8 단계, 이미지 3개 중 2개 Jazz Digi-Stix JDC11 Case Replacement: 8 단계, 이미지 3개 중 3개
    • Unscrew the three 5.6 mm Phillips #00 screws that connect the battery compartment to the case.
    • Remove the battery compartment from the case of the device.
  9. Jazz Digi-Stix JDC11 Case Replacement, Case: 9 단계, 이미지 2개 중 1개 Jazz Digi-Stix JDC11 Case Replacement, Case: 9 단계, 이미지 2개 중 2개
    • Remove viewer from the top-left corner of the case by gently pulling it away.
  10. Jazz Digi-Stix JDC11 Case Replacement: 10 단계, 이미지 1개 중 1개
    • If the replacement case does not have a wrist strap, remove your device's wrist strap by feeding the plastic tab through the loop cord, and then pulling it all the way through.
결론
작성자
4다른 기여자 명과 함께
Katelyn Fry
회원 가입일: 03/11/13
1 평판
안내서 7개를 작성함
Clemson, Team 12-3, Benson Spring 2013 Clemson, Team 12-3, Benson Spring 2013 회원
CLEM-BENSON-S13S12G3
3 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 9
전체 시간: 304
