주요 콘텐츠로 건너뛰기
Jazz Digi-Stix JDC11 Viewer Replacement
필요한 것
  1. Jazz Digi-Stix JDC11 Viewer Replacement, Battery: 1 단계, 이미지 2개 중 1개 Jazz Digi-Stix JDC11 Viewer Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Flip the device so that the bottom is facing upwards. Using thumb, push the tab on the bottom in the direction indicated by the arrow and then lift the unhinged part of the tab.
  2. Jazz Digi-Stix JDC11 Viewer Replacement: 2 단계, 이미지 1개 중 1개
    • Tilt device so that batteries slide out.
  3. Jazz Digi-Stix JDC11 Viewer Replacement, Viewer: 3 단계, 이미지 3개 중 1개 Jazz Digi-Stix JDC11 Viewer Replacement, Viewer: 3 단계, 이미지 3개 중 2개 Jazz Digi-Stix JDC11 Viewer Replacement, Viewer: 3 단계, 이미지 3개 중 3개
    • Carefully insert spudger into the seam on the top side of the device and tilt and twist the spudger to open the device. Work it around the device until the two case halves separate.
    • Before completely separating the two halves, grab the tab on the bottom of the device and pull the two halves of the case away from the hinged part of the tab so as not to break the plastic rods.
    • When separating the two halves of the case, be careful not to disconnect the various wires attached to the motherboard and the battery case.
  4. Jazz Digi-Stix JDC11 Viewer Replacement: 4 단계, 이미지 3개 중 1개 Jazz Digi-Stix JDC11 Viewer Replacement: 4 단계, 이미지 3개 중 2개 Jazz Digi-Stix JDC11 Viewer Replacement: 4 단계, 이미지 3개 중 3개
    • Pull the viewer free from the left hand side of the case.
결론
작성자
4다른 기여자 명과 함께
Katelyn Fry
회원 가입일: 03/11/13
1 평판
안내서 7개를 작성함
Clemson, Team 12-3, Benson Spring 2013 Clemson, Team 12-3, Benson Spring 2013 회원
CLEM-BENSON-S13S12G3
3 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 7
전체 시간: 389
