이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
If your device won't turn on and you wish to check to make sure the power button is not the cause, this guide will show you how to get to it.
필요한 것
Press down on the grooved plastic with your thumbs.
Push the back cover in the direction indicated by the small arrow on the grooved plastic. The back cover should slide right off.
Once you have the back cover off, the camcorder should look like this.
Look on the battery for a model number to assure that you acquire the correct replacement part.
The camcorder model number is located in the red box. Verify that you have a Jazz HDV178.
Remove the camera mount by unscrewing the 4.5 mm screw in the hole.
This is the bottom of the camcorder near where the wrist strap connects.
Remove the 4 mm screws holding the speaker onto the motherboard.
Once the speaker itself is unscrewed, remove the 4 mm silver screws that hold the connection wires to the LCD Display.
Remove the four Phillips head screws attaching the motherboard to the housing.
Once you removed the motherboard, remove the clear rubber button.
Use rubbeing alcohol on a Q-tip to clean the surface.
Allow to dry and wipe with a clean Q-tip.
다른 한 분이 해당 안내서를 완성하였습니다.
