주요 콘텐츠로 건너뛰기
Jazz UltraTab C1059-HL Antenna Replacement
필요한 것
  1. Jazz UltraTab C1059-HL Antenna Replacement, Antenna: 1 단계, 이미지 1/1
    • First step is to remove screws from top and bottom of device.
  2. Jazz UltraTab C1059-HL Antenna Replacement: 2 단계, 이미지 1/1
    • Remove the back panel of the device.
  3. Jazz UltraTab C1059-HL Antenna Replacement: 3 단계, 이미지 1/1
    • Upon removing the back panel, place the device screen down on the table.
  4. Jazz UltraTab C1059-HL Antenna Replacement: 4 단계, 이미지 1/1
    • Identify the antenna cover on the top of the device.
  5. Jazz UltraTab C1059-HL Antenna Replacement: 5 단계, 이미지 1/1
    • Remove the two screws holding the antenna cover in place.
  6. Jazz UltraTab C1059-HL Antenna Replacement: 6 단계, 이미지 1/1
    • Use a prying tool to remove the plastic piece off of the antenna component.
  7. Jazz UltraTab C1059-HL Antenna Replacement: 7 단계, 이미지 1/1
    • Identify the antenna component as the gray cable that comes out of the plastic cover.
  8. Jazz UltraTab C1059-HL Antenna Replacement: 8 단계, 이미지 1/1
    • Remove all of the adhesive tape pieces off of the antenna cable.
  9. Jazz UltraTab C1059-HL Antenna Replacement: 9 단계, 이미지 1/1
    • Once all of the adhesive tape has been removed. Pull out the antenna component.
  10. Jazz UltraTab C1059-HL Antenna Replacement: 10 단계, 이미지 1/1
    • The antenna will be attached to the chip in your device. Be careful not to pull off.
    • Solder of the wire that is connected to the chip in order to be able to remove the antenna component.
    • Once this is done, you can replace your old antenna with a new one!
결론
Amanda Justiniano
회원 가입일: 09/19/15
231 평판
안내서 2개 작성하였습니다
IUPUI, Team 1-3, Wilson Fall 2015 IUPUI, Team 1-3, Wilson Fall 2015 회원
IUPUI-WILSON-F15S1G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 190
