주요 콘텐츠로 건너뛰기
Jazz UltraTab C1059-HL Headphone Jack Replacement
필요한 것
  1. Jazz UltraTab C1059-HL Headphone Jack  Replacement, Headphone Jack: 1 단계, 이미지 1/1
    • Use a Philips screwdriver to remove the four screws: two at the top and two at the bottom of the device.
  2. Jazz UltraTab C1059-HL Headphone Jack  Replacement: 2 단계, 이미지 1/2 Jazz UltraTab C1059-HL Headphone Jack  Replacement: 2 단계, 이미지 2/2
    • Place the device screen down on the table and use a pry tool to remove the back panel.
  3. Jazz UltraTab C1059-HL Headphone Jack  Replacement: 3 단계, 이미지 1/1
    • For your safety, remove the battery.
    • Using a solder iron, remove the wires connecting the battery to the motherboard.
  4. Jazz UltraTab C1059-HL Headphone Jack  Replacement: 4 단계, 이미지 1/2 Jazz UltraTab C1059-HL Headphone Jack  Replacement: 4 단계, 이미지 2/2
    • Remove the screw attaching the motherboard to the back panel. Gently remove the motherboard.
  5. Jazz UltraTab C1059-HL Headphone Jack  Replacement: 5 단계, 이미지 1/1
    • The headphone jack is attached to the motherboard, so the whole thing must be replaced.
    • With the new mother board, use these steps in reverse to reassemble the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Tim Poe
회원 가입일: 09/26/15
361 평판
안내서 3개 작성하였습니다
IUPUI, Team 1-3, Wilson Fall 2015 IUPUI, Team 1-3, Wilson Fall 2015 회원
IUPUI-WILSON-F15S1G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 102
