주요 콘텐츠로 건너뛰기
Jazz UltraTab C1059-HL Screen Replacement
필요한 것
  1. Jazz UltraTab C1059-HL Screen Replacement, Screen: 1 단계, 이미지 1/1
    • First step is to remove screws from top and bottom of device.
  2. Jazz UltraTab C1059-HL Screen Replacement: 2 단계, 이미지 1/1
    • Remove the back panel of the device.
    • Be careful not to brake/bend the plastic cover of your device.
  3. Jazz UltraTab C1059-HL Screen Replacement: 3 단계, 이미지 1/1
    • Upon removing the back panel, place the device screen down on the table.
  4. Jazz UltraTab C1059-HL Screen Replacement: 4 단계, 이미지 1/1
    • Remove all data strips attached to the motherboard.
  5. Jazz UltraTab C1059-HL Screen Replacement: 5 단계, 이미지 1/3 Jazz UltraTab C1059-HL Screen Replacement: 5 단계, 이미지 2/3 Jazz UltraTab C1059-HL Screen Replacement: 5 단계, 이미지 3/3
    • Remove the tape around the battery.
    • One of these pieces of tape holds down the battery connection to the mainboard.
    • Use the soldering iron to disconnect these wires.
    • You will need to use a tool to pry off the battery. It will have a good amount of adhesive holding it down.
    • Be cautious not to bend the battery when prying.
  6. Jazz UltraTab C1059-HL Screen Replacement: 6 단계, 이미지 1/1
    • Once the battery is removed, make sure to remove any and all data strips that are attached.
    • Then begin to unscrew the mother board.
  7. Jazz UltraTab C1059-HL Screen Replacement: 7 단계, 이미지 1/1
    • Remove the motherboard chip off of the device.
  8. Jazz UltraTab C1059-HL Screen Replacement: 8 단계, 이미지 1/1
    • Your board should look like this after taking all of the components off the screen panel.
  9. Jazz UltraTab C1059-HL Screen Replacement: 9 단계, 이미지 1/2 Jazz UltraTab C1059-HL Screen Replacement: 9 단계, 이미지 2/2
    • Remove the Display Module from the screen cover.
  10. Jazz UltraTab C1059-HL Screen Replacement: 10 단계, 이미지 1/1
    • Now, you can replace your broken or damaged screen!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Amanda Justiniano
회원 가입일: 09/19/15
231 평판
안내서 2개 작성하였습니다
IUPUI, Team 1-3, Wilson Fall 2015 IUPUI, Team 1-3, Wilson Fall 2015 회원
IUPUI-WILSON-F15S1G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 443
