주요 콘텐츠로 건너뛰기
Jazz UltraTab C1059-HL Speaker Replacement
필요한 것
  1. Jazz UltraTab C1059-HL Speaker Replacement, Speaker: 1 단계, 이미지 1/2 Jazz UltraTab C1059-HL Speaker Replacement, Speaker: 1 단계, 이미지 2/2
    • Start by removing the back panel.
    • Remove the 4 screws holding the device together: two on the left side, and two on the right side.
    • Using a metal spudger, carefully pry open the case.
    • With the screws gone, the case is held together with clips along the outside edge of the aluminum backplate.
    • Undoing these clips can take a bit of force. Be cautious not to damage the plastic edge of the device.
  2. Jazz UltraTab C1059-HL Speaker Replacement: 2 단계, 이미지 1/1
    • Place the device on the table with the screen-side down.
  3. Jazz UltraTab C1059-HL Speaker Replacement: 3 단계, 이미지 1/1
    • This is the Speaker.
    • Remove the two black screws.
  4. Jazz UltraTab C1059-HL Speaker Replacement: 4 단계, 이미지 1/1
    • Remove black tape from the wires.
    • Keep this tape, you will need it for reassembly.
  5. Jazz UltraTab C1059-HL Speaker Replacement: 5 단계, 이미지 1/1
    • Using a soldering iron, heat up the spot where the speaker wires connect to the mainboard.
    • Remove Speaker wires when the solder liquifies.
    • Remember to make note of where each wire is connected. When reinstalling the speaker, it is important that the wires are reattached to the same spot.
  6. Jazz UltraTab C1059-HL Speaker Replacement: 6 단계, 이미지 1/1
    • Remove the speaker.
    • Replace the speaker by following these steps in reverse.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Tim Poe
회원 가입일: 09/26/15
361 평판
안내서 3개 작성하였습니다
IUPUI, Team 1-3, Wilson Fall 2015 IUPUI, Team 1-3, Wilson Fall 2015 회원
IUPUI-WILSON-F15S1G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 95
