주요 콘텐츠로 건너뛰기
Jazz UltraTab C855 Battery Replacement
필요한 것
  1. Jazz UltraTab C855 Battery Replacement, Back Cover: 1 단계, 이미지 1/1
  2. Jazz UltraTab C855 Battery Replacement: 2 단계, 이미지 1/1
    • Pry the back case off using the blue Plastic Opening Tools. Work one along the seem until you can get your fingers under to pull it apart.
  3. Jazz UltraTab C855 Battery Replacement, Battery: 3 단계, 이미지 1/1
    • Remove the yellow tape from the sides of the battery, and the surrounding components.
  4. Jazz UltraTab C855 Battery Replacement: 4 단계, 이미지 1/1
    • Cut the pos(+) and neg (-) wires that connect the battery to the device using wire cutters.
    • Cut the wires towards the middle. During installation of your new battery these wires will be stripped back and soldered or crimped to reattach.
  5. Jazz UltraTab C855 Battery Replacement: 5 단계, 이미지 1/1
    • Using a plastic opening tool or spudger, slowly pry the battery away from the board.
    • The battery is secured to the device with adhesive.
    • Metal spudgers can puncture an unprotected battery, potentially causing a fire. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  6. Jazz UltraTab C855 Battery Replacement: 6 단계, 이미지 1/1
    • Use a two sided adhesive to secure the new battery in place.
    • Solder or crimp the wires back together to reattach to the motherboard.
    • Replace any yellow tape that you removed at the beginning to secure the wires back in place.
결론
Cory Hodge
회원 가입일: 09/14/15
201 평판
안내서 2개 작성하였습니다
IUPUI, Team 1-3, Baechle Fall 2015 IUPUI, Team 1-3, Baechle Fall 2015 회원
IUPUI-BAECHLE-F15S1G3
5 회원들
안내서 10개 작성하였습니다
댓글 한 개
Very good instructions.....but where do I buy the repkacement battery from?
fremontmyers - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 538
